Latest post Mon, Jul 22 2019 7:40 PM by Telegram!. 9 replies.
Page 1 of 1 (10 items)
  • Fri, Jul 19 2019 4:03 PM
    • mmagder
    • Joined on Wed, Sep 1 2010
    • Passaic NJ
    • Posts 232
    • Points 2,985
    Can you preset the Quick Transition box to open with any other length a than 30 fr dissovle
    Can you preset the Quick Transition box to open with anything other than a 30 fr dissovle. Can i make it 2O or some other number that i use all the time instead of having to change it everytime i make a dissolve. Or do it some other way. This has been bugging me for years. It seems so obvious, but like everything else in Avid you can never find it!
    Sorry for the hostility and bitterness!
    thanks
    Mac OSX 10.14.5 3.8 GHz Intel Core i5 MC 2019.7 [view my complete system specs]
  • Fri, Jul 19 2019 4:18 PM In reply to
    Re: Can you preset the Quick Transition box to open with any other length a than 30 fr dissovle
    MC 2020.6, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 64GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Fri, Jul 19 2019 5:36 PM In reply to
    • mmagder
    • Passaic NJ
    • Posts 232
    • Points 2,985
    thank you, i tried to follow the instructions, i can't get the preset to show up in the pull down in the quick transition box? Do you know where the this folder is inside avid?
    thanks
  • Fri, Jul 19 2019 6:36 PM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 166
    • Points 2,165
    It's not a folder. It is just a bin that you have to create and keep in your project. Put your templates inside that bin and that should do the trick. It still works, even in 2019.6
  • Fri, Jul 19 2019 8:30 PM In reply to
    • mmagder
    • Passaic NJ
    • Posts 232
    • Points 2,985
    Thats what i did, doesnt show up?
  • Fri, Jul 19 2019 9:39 PM In reply to
    • Cutyes
    • Berlin
    • Posts 166
    • Points 2,165
    Bin name spelled correctly? Upper/lower case, space, 's' at the end? Maybe an exotic character in the template's name? Did you save/close the bin?
    The mandatory question: did you create new user settings for 2019.6?
    I guess using the template manually (dragging it from the bin onto your edit) would not already speed things a little up for you?
    Edit: I wonder if the pull down menu item would really make it faster for you. Because [open menu]+[select template]+[return] will probably take more or less the same time as [type in dissolve value]+[press return]. If there is no nifty way in Media Composer itself - I don't know, but maybe someone else does - you could use something like Keyboard Maestro, save your favourite dissolve as a macro, map it to a key and you would have a one button solution.
  • Sat, Jul 20 2019 7:26 AM In reply to
    mmagder:
    thanks
    Hi mmagder, “
    Don’t blame Avid or yourself— I think You cannot find a way to do what you want because it’s hiding in plain sight. After studying the Quick Transition tool for like 2 minutes and 20+ years,  I have observed that when you first press the Quick Transition button while parked on an edit, It defaults to a 30 Frame Centered Dissolve with the cursor parked on the Duration field ready to receive your preferred number, then to be followed by Enter. And here’s the beauty part-  the next time you use Quick Transition tool it’s all the same as last time except it defaults to your previous number, (no longer 30, right?). So it seems Avid in its infinite wisdom has read your mind and is giving you a super quick way to repeat your favorite length, who-cares-just drop a centered Dissolve on it, effect. I prefer “33” because it’s easier to type  and I could save it in the “Quick Transitions” Bin — a trick that still works, and Cutyes is very correct, you do not leave off the ‘s’, even though the tool itself does, which is so cool and why we love our Media Composer software, for stuffs justs likes thats!
    Now you can help me, and please feel free Thanks! to add some good-natured hostility in you reply: Is it just my system or is anyone else not able to type anywhere into the Quick Transition box until they move it slightly first?
    (v2019.6 Win)?
    Thanks!
  • Sat, Jul 20 2019 10:07 PM In reply to
    • Aren Hansen
    • Joined on Tue, Mar 15 2016
    • Toronto
    • Posts 72
    • Points 780
    I use keyboard maestro to do exactly this. Works great.
    MC 2020.8 // OS10.15.6 // iMac 2019 3.6 i9 // 72GB Ram // Vega 48 // [view my complete system specs]
  • Sun, Jul 21 2019 5:19 PM In reply to
    • mmagder
    • Passaic NJ
    • Posts 232
    • Points 2,985
    Wow that got it!!! Thanks i always saw it was doing something with last edit, but i never really put it together. Avid shoiuld really give out awards for the best answer of the day! month year ect.
    As far as your question, i can type into my q t box without moving it.
    All the best
    and thanks again
  • Mon, Jul 22 2019 7:40 PM In reply to
    mmagder:
    All the best
    and thanks again
    You’re welcome! It’s very handy to know and you’ll see how you can simply park on an existing effect, click Add and have it‘s values ready on a new Quick Transition effect. Thanks for checking on that other thing, too.
