Latest post Thu, Jul 11 2019 2:52 PM by persyst. 4 replies.
  • Thu, Jul 11 2019 12:40 PM
    • persyst
    • Joined on Tue, May 27 2014
    • Posts 212
    • Points 2,715
    4K linked files super choppy playback
    Greetings!
    I'm trying to create a rough cut sequence using the original GoPro Hero 7 and Sony RX100M6 4K footage in my timeline to avoid transcoding a bunch of files I'll never use, but the playback in both the source and record monitors is unbearably choppy using the camera files, even with proxy set to 1/16 and timeline resolution set to yellow. My system specs are below. Can anyone recommend how to remedy this problem, without transcoding?
    My files are reading/writing a G-Tech Studio RAID thunderbolt 24TB drive.Would I see improvents in LINKED playback using an SSD drive? If so, please let me know which drive options might be the way to go.
    If it's not the drive that's the problem, please let me know what might be.
    Thanks!!!!
    System Specs
    Media Composer 8.4.5 Pro Tools 2018.12 Mac Pro 2013, MacOS High Sierra 10.13.6 • 2.7GHz 12-core with 30MB of L3 cache • 64GB (4x16GB) of 1866MHz DDR3 ECC • 1TB PCIe-based flash storage • Dual AMD FirePro D700 GPUs with 6GB of GDDR5 VRAM Video file read/write drive • G-Tech Studio thunderbolt RAID 24TB
    Media Composer 2020.6 Pro Tools 2019.6 Mac Pro 2013, MacOS Mojave 10.14.6 • 2.7GHz 12-core with 30MB of L3 cache • 64GB (4x16GB) of 1866MHz DDR3 ECC... [view my complete system specs]
  • Thu, Jul 11 2019 2:01 PM In reply to
    • Editmvp
    • Joined on Wed, Sep 3 2008
    • Billings, Montana
    • Posts 182
    • Points 2,145
    Re: 4K linked files super choppy playback
    What is the frame rate of the 4k footage?  If it's 59.94, it's very difficult to get smooth playback at any resolution, at least on my system.  But when I change to a 30p project (29.97) the 4K footage plays perfectly.  The choppyness seems to be more related to frame rate than resolution.
    Primary System: Media Composer Ultimate 2024.12 | Avid Artist DNxIO | iMac 2020 i9 10-Core 3.6/128GB/2TB-SSD/Radeon Pro 16GB / OS 15.3.x | Artist Color... [view my complete system specs]
  • Thu, Jul 11 2019 2:38 PM In reply to
    • persyst
    • Posts 212
    • Points 2,715
    The Hero 7 footage is 4K 60fps and the Rx100M6 is 4K 24fps. I set my initial project type as UHD/23.976 FPS. Any suggestions?
    thanks
  • Thu, Jul 11 2019 2:43 PM In reply to
    • Editmvp
    • Billings, Montana
    • Posts 182
    • Points 2,145
    Try right-clicking on one of the Hero clips to access the Source Settings and change the playback rate to 24fps.  The footage will play as slo-mo, but you can do a mixdown and add a motion effect to bring the speed back to normal.
  • Thu, Jul 11 2019 2:52 PM In reply to
    • persyst
    • Posts 212
    • Points 2,715
    Ah thank you, I’ll give that a shot and get back with the results!!
