Latest post Sun, Jul 28 2019 10:09 PM by Van LaPointe. 32 replies.
Page 1 of 3 (33 items) 1 2 3 Next >
  • Mon, Jul 8 2019 6:28 PM
    Avid Media Composer 2019.6 won't restore from being minimized
    Whenever I minimize Media Composer 2019.6 I can't get it back and literally have to use the task manager to crash out and restart.  I'm using Windows 10 Pro on a dual monitor setup.  I can see the right screen (which never does get minimized) but for the bloody life of me, the rest of it won't come back. OMG how crap is this...I just use the "show desktop" function as a workaround which works, but OMG don't use minimize!  Anyone else?
    HP Z840 Windows 10 Pro Dual E5-2690v4 2.6Ghz 14-core NVIDIA P6000 24 GB 64 GB RAM BCC 2020/Sapphire 2020/Mocha Pro/Titler Pro 7 BMD Studio 4K G Technology... [view my complete system specs]
    Dan Meadows
  • Mon, Jul 8 2019 6:42 PM In reply to
    Re: Avid Media Composer 2019.6 won't restore from being minimized
    Are you Right-Clicking on the minimized MC window ? I had the same issue, but it went away after I chose Media Composer, bear bottom of the “Recent” list. HTH
  • Mon, Jul 8 2019 6:52 PM In reply to
    Yeah, right clicking on that and choosing MC or any of the bins doesn't work for me.  (I have MC pinned to the taskbar.)  Neither does choosing "switch to" in the task manager.  If I right click on the icon in the task bar and the hover over the image of MC that appears (the right window only) it will bring the left window back up but as soon as I come off of that image or click on the laft window if goes away again.  Definitely messed up.   Again, thanks for your response!
    Dan Meadows
  • Mon, Jul 8 2019 7:00 PM In reply to
    I am using a 1 monitor system, so I may be immune, for now. Just CURIOUS: Are your Customized Workspaces Floating or Panelled or each a combo ? Also: are you able to use Restore on one of your Default Workspaces to determine if minimizing from there also “sticks”? And also: are you using the workspace sidebar or have it in “Hide” ?
  • Mon, Jul 8 2019 7:08 PM In reply to
    The workspaces are mostly panelled.  One has a floater.  They're really just the defaults but with extra tools added to them and with timeline views linked etc.  No I'm not able to restore (from minimized) a default workspace.  I am using the workspace sidebar in icons only mode.
    Dan Meadows
  • Mon, Jul 8 2019 7:15 PM In reply to
    Thanks for the details. Good luck. What about testing as a 1-monitor system? I think you need help from tech support.
  • Mon, Jul 8 2019 7:18 PM In reply to
    I think I'll contact them.  Hey thanks a lot for your time - much appreciated!
    Dan Meadows
  • Mon, Jul 8 2019 7:28 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 689
    • Points 7,760
    initially i had a similar type of problem with the auto hide the taskbar ON
    turning it off did the trick.
    hth...
    symphony 2020.8 - win 10 pro64 v.1909 - QT essential 7.7.9 - nVidia gtx1080 OC (452.06 studio) - intel i7 6800k @4.2ghz water cooled by corsair H100i V2... [view my complete system specs]
  • Tue, Jul 9 2019 1:37 PM In reply to
    • opie177
    • Joined on Wed, Nov 18 2009
    • Chicago
    • Posts 72
    • Points 1,010
    I have the same issue. When I minimize the main window... anything panelled on the right monitor stays, but the HOME program window is gone. I cant access the top menus (FILE, EDIT, Ect) and have not found a way to get them back without crashing out and restarting.
    HPZ820, 2.6GHz,32G, Win10, NitrisDX, MC12.6 [view my complete system specs]
  • Wed, Jul 10 2019 10:00 AM In reply to
    • Tim
    • Joined on Mon, Sep 12 2016
    • Posts 26
    • Points 285
    I can confirm the same issue here with a 2 monitor setup. Main monitor comes back, left monitor (where the control menu's are) wont come back.
    AVID MC 2020.8 / Blackmagic Intensity Pro 4K / Intel Core i7-7700K @ 4.2ghz / 64GB ram / GeForce RTX 2080 Ti / Windows 10 pro / [view my complete system specs]
  • Wed, Jul 10 2019 1:08 PM In reply to
    Thanks for thinking of this...I don't have that switched on.
    Dan Meadows
  • Wed, Jul 10 2019 3:54 PM In reply to
    • ramz434
    • Long Island
    • Posts 234
    • Points 2,925
    This is a problem I had until I made the windows task bar appear all the time. Previously I had it hidden and the app would minimize itself into a little bar that would get hidden behind the taskbar. Don't know if you have the task bar hidden or if its up permanently. But after playing around with this and tweaking the host panel to have them BOTH active (but my left one primary) - at least it reactivates when minimized. Still only get one monitor to minimize though
    - HP Z400/24gb ram/Windows 10/MC2020.5/256gb Samsung SSD/ NVidia GTX 1080 - Macbook Pro/16gb ram/OS 10.15.4/MC2020.4/Intel UHD 630 [view my complete system specs]
  • Wed, Jul 10 2019 4:09 PM In reply to
    Thanks for this ramz434, this helped! I don't have my taskbar setup to minimize - it's there all the time and both windows are also active under host panel.  And I can't click on the icon on the task bar to restore after minimizing  BUT (thanks to your attached picture) if I double click on that little Avid Media Composer Moj... window it comes back up.  Cool...but not how it's supposed to work I'm sure.
    Thanks - much appreciated!
    Dan Meadows
  • Wed, Jul 10 2019 5:01 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,774
    • Points 48,230
      Moderator: MCA Mac
    I can confirm the behavior as described. Most annoying is that the panel on the secondary monitor doesn't minimize.
    Dave S.
  • Sun, Jul 14 2019 10:39 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 299
    • Points 3,575
    I can also confrim the same problem - cannot minimize.  Like someone else said I have to go into the task manager to get MC back.  Will look into some the fixes others have said, but I think this is a bug.
    Symphony 2020.8 - Win 10 pro (1909),Gigabyte X299X with i9 10920X cpu, Quadro P2000, 64gig memory, 1TB NV ystem drive, WD 4TB, BM Min Monitor, 11.7 drivers... [view my complete system specs]
