Latest post Sun, Dec 1 2019 3:17 AM by Fazz Powell. 93 replies.
Page 6 of 7 (94 items) « First ... < Previous 3 4 5 6 7 Next >
  • Tue, Nov 26 2019 5:50 PM In reply to
    Re: Please provide basic user info on Titler+
    LDV20:
    In the meantime I go to AE - I just do not know AE that well -wish Titler+ was useful
    I have gotten proficient at going in/out of Photoshop to do 4K titles.   I export a screenshot from MC and use that as a base layer in Photoshop to postion the graphics.   Save the Photoshop graphic as a PNG with alpha channel (hiding the screenshot before saving) then import the PNG file into MC and use the effects editing parameters to make final adjustments.
    Still not as fast as the old Title Tool but for non-animated graphics, Photoshop is quite capable and easier than After Effects.
    MC 2018.12.3 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system... [view my complete system specs]
  • Tue, Nov 26 2019 11:52 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 282
    • Points 3,345
    thank you Terry - will try this - good tip for title
    thank you
    Larry
    Symphony 2020.5 - Win 10 pro (1903), Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,(441.28) 64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media... [view my complete system specs]
  • Wed, Nov 27 2019 1:30 AM In reply to
    I would think at this point, a tutorial is not going to matter.  If the people of this forum, who I'm sure, are all talented professionals, cannot figure out how to use this thing without a step by step guide, then it's not us, it's them.
    I would hope the silence from Avid is because they are in a scrabble to release a totally overhauled version that does actually work.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 32GB RAM Win 10 Pro MC Ultimate 2018.12.11 MacbookPro 15 2019 6 core 2.6GHz i9... [view my complete system specs]
  • Wed, Nov 27 2019 3:41 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,744
    • Points 47,975
      Moderator: MCA Mac
    LDV20:
    Someone wrote a step by step in th forum
    I am that someone. At this point, Titler+ still needs a lot of work. There are other products you can use. And as I've mentioned, you can still use Marquee to get a 4K (or 8K) title (true 4K/8K, not uprezzed). The only downside is I don't believe it's still in development, but is at least is still functional and comes with Media Composer.
    Dave S.
  • Wed, Nov 27 2019 2:10 PM In reply to
    • LDV20
    • Posts 282
    • Points 3,345
    Thank you for the steps - will be trying it to see if I can get just simple titles without getting frustrated -
  • Wed, Nov 27 2019 8:34 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,743
    • Points 61,875
    In 2019.11 there have been many improvements but simple animation of multiple text layers is not one of them. Still broken - in fact, keyframing of any parameter is a challenge (and keyframes magically appear without warning). Hopefully this gets some love before the end of the year (it's been almost a year since it was first introduced and proudly touted as one of the great new features of Media Composer for 2018/2019).
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Nov 28 2019 3:43 AM In reply to
    Anyone using Title Studio from Boris? Can be bought as a filter for $149 currently.  GPU accelerated, 8k+ resolution, output to external monitor.  Sounds good. Does anyone have any experience with it? Pricey but at least it might work...
    Andi
  • Thu, Nov 28 2019 12:29 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,743
    • Points 61,875
    Sure - BCC Title Studio is very powerful, however, it is most powerful when combined with other BCC filters to perform actions such as 'match move' and corner pinning... If you have deep pockets, the entire BCC 2020 suite is highly recommended. I am not an expert in using BCC Title Studio and I find that creating simple titles is a bit more difficult that it is with the original Avid title tool but with some practice that can probably be overcome. Plus, they have quite a few customizable presets that you can load and browse. You should be able to download it and play with it in a watermarked mode, I would think.
    Steve
  • Thu, Nov 28 2019 4:18 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,744
    • Points 47,975
      Moderator: MCA Mac
    So, a bit more fun and games with Marquee. I created a relatively simple (1 line of text) 8K title and animated it using one of the built-in presets, and then rendered it out. Let's just say it's a bit slow. As in 30 seconds per frame slow! So while it does work, rendering out anything animated is going to be slow (a known problem, but it scales up with frame size).
    Dave S.
  • Fri, Nov 29 2019 2:50 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,155
    • Points 24,005
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hi Community peeps,
     Here's the much awaited tutorial link for the Titler+. Thank you so much for your patience and apology for the delay.
    Raff/Marianna
  • Fri, Nov 29 2019 2:56 PM In reply to
    This link won't let me sign in to view it.  Why on earth do I need to sign in to view this, why isn't it just available to everyone??
    Andi
  • Fri, Nov 29 2019 3:03 PM In reply to
    • Aren Hansen
    • Joined on Tue, Mar 15 2016
    • Toronto
    • Posts 71
    • Points 765
    Hi is there a tutorial for how to access this tutorial? :)
    2018.12.7 // OS10.14.5 // iMac 2019 3.6 i9 // 72GB Ram // Vega 48 // [view my complete system specs]
  • Fri, Nov 29 2019 3:11 PM In reply to
    Aren Hansen:
    Big Smile
    At least Avid is consistent in making something that should be easy harder than it needs to be...like the Titler+ tool itself.
  • Fri, Nov 29 2019 3:46 PM In reply to
    • LDV20
    • Posts 282
    • Points 3,345
    RalphC:
    Please make this link accessable - could not get it to work
    thank you
    Larry
  • Fri, Nov 29 2019 4:26 PM In reply to
    • RalphC
    • Posts 2,155
    • Points 24,005
      Avid Employee
    Sorry let me check the link.
    Update:
       Please try it now. We will upload it later to the tutorial section.
    RalphC
