Latest post Wed, Jul 22 2020 8:09 PM by ZorkNation. 22 replies.
Page 2 of 2 (23 items) < Previous 1 2
  • Wed, Jun 26 2019 2:03 PM In reply to
    Re: NewBlueTitler doesn't activate
    Seth from New Blue FX also investigates why NewBlueFX transitions aren't present in Effects.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Sun, Mar 29 2020 5:35 AM In reply to
    I started getting this problem in 2019.12.0.
    Titler Pro Express doesn't work either.  MC crashes.
  • Sun, Mar 29 2020 11:31 AM In reply to
    • Posts 11,260
    • Points 231,840
    Zork
    Let me check ....
  • Sun, Mar 29 2020 3:06 PM In reply to
    I'm using a Mac btw, Mojave
  • Tue, Mar 31 2020 10:33 PM In reply to
    ZorkNation:
    Hello Zork,
    What version of Titler Pro do you have installed? And what exactly the issue, that it's not activating or that you're having stability issues with it?
  • Fri, May 1 2020 2:24 PM In reply to
    • Derek young
    • Joined on Tue, Apr 26 2011
    • Oxfordshire UK
    • Posts 20
    • Points 230
    I am in the same situation. I have just upgraded Avid to 2020.4  downloaded and installed Titler Pro Express for Avid and I find that Titler Pro for Avid states thatit is current whilst below in the NewBlue App Manager, the Titler Pro for Avid needs to be activated. A message comes up saying "Unable to activate because of failure to communicate with AvidELF.
    I followed your previous advice of logging out and then back in without success.
    In Media Composer when applying NewBlue FX/transitions, I get the cross and FX water mark. Is this because Titler Pro is not activated?
    I am running Media Composer on a Dell PC.
    Derek
  • Fri, Jun 26 2020 9:49 PM In reply to
    Derek young:
    Derek
    Hi Derek,
    Apologies for the very late response, and for my extended absence on this forum. In case you're still having this issue, and for the benefit of other users I'm going to respond.
    For anyone who is installing Titler Pro 7 Express for Avid, I would suggest uninstalling Titler Pro 5 for Avid first. The "AvidELF" error is specifically for Titler Pro 5, since it is discontinued and can no longer be activated.
    To answer your other question, if the NewBlue effects and transitions you have came with Titler Pro 5 for Avid, then they cannot be activated anymore and you will always get the watermark. All of those effects and transitions are of course available to purchase from our website, or you can also take a look at TotalFX, which includes Titler Pro 7 Ultimate as well as all our effects and transitions and is available as a subscription: https://newbluefx.com/products/totalfx/
  • Wed, Jul 22 2020 8:09 PM In reply to
    Marcus Johnson:
    Derek young:
    That was apparently not possible when I tried this before.  I tried many times.  AvidLink automatically reinstalled Titler Pro 5.  It offered no option to uninstall.
    I tried the uninstaller in the "NewBlue Uninstallers" folder under Applications.  It didn't apparently do anything except delete the uninstaller program.
    Or maybe this has changed now?  Now AvidLink doesn't show the old Titler Pro, but gives an option under "Included Apps and Plugins" to download version 7.  That's weird because version 7 appears to be installed already.  I tried uninstalling that too.  Now it says it's gone.  So I'll try downloading version 7 through AvidLink and see what happens.
    I was able to install, but it crashes every time I use it.  I import a simple video clip.  I add a second video track and select only that track.  I set in and out points and mark that section of filler.  I drag the NB Titler 7 plugin onto that section.  I go to the Effects Editor and click to launch the user interface.  I create a title and wait for the green circle to fill for the render.  Then I close the user interface.  It prompts me to save.  I save.  Then Media Composer crashes, every time.
