Latest post Thu, Jan 9 2020 2:00 PM by Marianna. 24 replies.
Page 1 of 2 (25 items) 1 2 Next >
  • Mon, Jun 3 2019 2:32 AM
    • Harry Invision
    • Joined on Wed, Feb 3 2010
    • Brisbane, Australia
    • Posts 102
    • Points 1,220
    Background Service Failing
    Hi All,
    Just trying Ingesting and Transcoding using BG Service works direct but in the queue it is failing with this error.
    Exception:BG_UniSink instance is not compatible with BG_CompositeSink instance.
    Any ideas....Harry
    Media Comoposer Ultimate 2020.6 + Symphony DX Nitris HP Z840 E5-2659 Quadro P4000 32Gb of Ram Win 10 64bit 64TB Editshare 16TB Internal Raid HP Z400... [view my complete system specs]
  • Tue, Jun 4 2019 12:59 AM In reply to
    • Harry Invision
    • Posts 102
    • Points 1,220
    Re: Background Service Failing
    Transcoding is the problem by the looks...transcoding via Media Encoder now and then queuing.
  • Tue, Jul 2 2019 7:56 PM In reply to
    Anybody run into this?  I'm having the same issue as Harry on my 2018.12.2 install.  No background transcode for UHD clips captured from DJI Osmo Pocket 4k.  All clips error out:
    Exception: BG_UniSink instance is not compatible with BG_CompositeSink instance
    Avid Media Composer 2018.12 Intel i9 9900K desktop Windows 10 Pro 64GB RAM BlackMagic Design Decklink Mini Monitor Nvidia RTX2080 display card [view my complete system specs]
    Jason Spencer, Director/DP/Editor digitallunchbox.com
  • Tue, Jul 2 2019 9:39 PM In reply to
    • Harry Invision
    • Posts 102
    • Points 1,220
    I gather it works while not using BG Transcoding, like for me? I think maybe its the codec, BG works for most, just not some.
    If you have a huge amount use Media Encoder....I had 65 days worth...therapy awaits...
  • Wed, Sep 11 2019 4:46 PM In reply to
    Having this problem AGAIN.  H.264 files.  Garden variety stuff.  Should be a piece of cake.  Anyone else seen this error in the background queue?  Foreground transcoding works without a hitch.
  • Wed, Sep 11 2019 8:46 PM In reply to
    • Harry Invision
    • Posts 102
    • Points 1,220
    Hi Jason,
    Hopefully a fix soon, it just hates H264. Has worked with previous version as I do a yearly Series, I know it used to work.
    Best I can offer is Media Encoder in Background I was going to DNxHD120 or 85.
    It was actually quicker on huge volumes of work quick ingest and faster transcode. ie 65 days worth.
    I havent tested on latest release on 12.6 at moment...Good Luck...Harry
  • Wed, Sep 25 2019 3:52 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,251
    • Points 14,965
    wjasonspencer:
    Yes absolutely same problem hereSuper Angry.
    This happens with MP4 (H.264) files (others not tested) linked with the infamous* Avid Generic plug-in. BG Transcode works just fine when forcing link using QT plug-in !
    After having reinstalled 18.12.7 from scratch and still seeing the problem, I was up to opening a case, but perhaps this is already logged as a bug by someone else then ???
    (*despite being EOL and being slower, the QT plug-in is always a better choice for me: beside problematic BG transcodes, the Avid Generic plug-in causes more banding and uneveness in levels mapping than the QT plugin -> a case still being under investigation)
    MC 2018.12.10 (+Symphony)/BCC2019 12.5.2/RED 5.6; BlackMagic Ultrastudio Mini Monitor+Recorder (11.4.1); DELL Precision 5530 - Intel Core i7-8850H 2.6... [view my complete system specs]
  • Fri, Sep 27 2019 2:42 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,747
    • Points 48,000
      Moderator: MCA Mac
    I use ffmpeg https://www.ffmpeg.org/ rather than Media Encoder. It's free, and it's reasonably fast. But you really need to learn how to use the command line interface. A good freeware GUI for it is Avanti http://www.avanti.arrozcru.org/. Avanti also has a batch mode for processing lots of files.
    Dave S.
  • Fri, Sep 27 2019 4:12 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,251
    • Points 14,965
    I use ffmpeg with AnotherGUI very occasionally (can ffmpeg do DNxHR?)...but background transcode is so convenient!
    Does anyone know if this is logged already (or if I should do it) ?
  • Fri, Sep 27 2019 4:44 PM In reply to
    Yeah guys... FFMpeg... another workaround to a feature that should "just work."  That's nice, but I'm PAYING for Avid's software, not workarounds.  Background transcode, Avid generic plugin, strange playback performance issues with Blackmagic hardware - several key things BREAKING in MC as of recent that have followed me across PC systems, so it's not limited to one machine.  I don't run Mac - thank goodness - or I guess I'd add rebooting problems to the list too!   At some point the straw is going to break... well.  You know.
    I ended up transcoding every h.264 file to DNX in Adobe Media Encoder, because I just had to get back to work and stop fiddling with something that was just going to be broken no matter what.  Because evidently every Avid editor needs an Adobe subcription. Hmm
  • Sun, Sep 29 2019 11:50 AM In reply to
    Since upgrading to 2019.7, Background Render has been broken for us. It says it's running, but the progress meter doesn't move. The progress meter internal to Avid has NO progress, while the external browser version has a start bar but never completes. Our projects are UHD 29.97.
    Windows 10 Enterprise - Dell Precision 7820 - 32GB RAM - DNxIQ - Nvidia Quadro P4000 [view my complete system specs]
  • Mon, Sep 30 2019 1:56 PM In reply to
    • Posts 11,267
    • Points 231,935
    BenoitM:
    Folks....  It is logged as MCDEV-11528
    BeniotM - creating cases for everyone so it gets more eyes on it.
  • Tue, Oct 1 2019 9:30 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,251
    • Points 14,965
    Marianna:
    Yesthanks Marianna!
  • Tue, Oct 1 2019 5:41 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,744
    • Points 61,880
    Would you be able to post an MP4 file that you cannot background transcode? I am running MC 2019.9 and I don't seem to have any problems background transcoding various media (whether it be the generic plugin or others such as the MXF plugin or the Nabblet XAVC plugin - they all work).
    Steve
    ______________________
    www.nelliedogstudios.com
  • Tue, Oct 1 2019 7:07 PM In reply to
    Noticed you're on 2019... brave man! Big Smile It sounds like everyone involved is having issues with 2018 versions.  I'm on 2018.12.6. I will try to send my media as soon as I can.  I know I've sent them media/bins already related to the Avid Generic plugin's timecode irregularities, but not necessarily the background transcode issue.
