Using setting 1080p 29.97 DNXHD 100.
Unable to change data rate and profile is locked at MEDIUM QUALITY
Data-rate control is not operable ?????
Trying to push best possible quality to You Tube
Matthew Clulow
Is there a question in here?
All DNx flavors are locked to specific standards. There are no variables in the video bitrate or codec that can be altered. If it was customizable, then it would be no longer DNx100.
We do much of our HD work in that flavor of codec and works well for us.
If you want to go higher, you can go to DNx145 or DNx220. Changing specs on export take a long time, by the way. It may be better to do a mixdown to the resolution you want and then export "same as source" for the fastest export.
I hope this helps.
M. Cebrian
Thx. I'll try this
X at the end 220X etc indicates that the project could be used for 10bit editing exporting.
Desktop
Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
Laptop
MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
NLE
DR Studio 19.1.3|MC 2024.12
VDIM
I will also add that if you are exporting files that might need to go into other systems like Adobe/PP, Resolve, Etc there can be a strong argument to not use the QT/mov export but to use the Op1a set to the DnX you want.
Advantages are:
1)export/import faster
2)mov files are slowly being supported less.
3) and main one. seems to eliminate and level shift issues when importing into another system/softwares.
