Latest post Wed, May 20 2020 2:14 PM by dlogneb. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Feb 4 2019 10:14 PM
    • Rawb24
    • Joined on Fri, Mar 2 2018
    • Posts 13
    • Points 135
    Create Multigroup Bug - 2018.12 & 2018.12.1
    We've come across a bug in 2018.12 and 2018.12.1, wondering if anyone else has experienced this. We used the new Create Multigroup feature and when the group is opened in an older version of Avid (2018.11 and lower), we're not able to click on the camera bank when viewing Quad or 9-Split. It works fine in the same version but not older ones.
    It seems to have this issue when there are multiple sections in the timeline, as there would be in a normal reality TV syncmap, as cameras/audio start and stop throughout the day. If there's only one section, it seems to work fine.
    I recorded some video of me putting together a group and testing it. There are two videos. GROUPING 2018.12 is of me creating the group in 2018.12, which worked. GROUPING 2018.11 shows me opening up this group in 2018.11 and it not working. I did not change anything between these steps - just closed it in one and opened it in the other. You can view them here:
    GROUPING 2018.12 - https://youtu.be/VB7Jo2C1JpI
    GROUPING 2018.11 - https://youtu.be/113La04BHZs
  • Wed, Feb 6 2019 6:16 PM In reply to
    • Posts 11,124
    • Points 230,130
    Re: Create Multigroup Bug - 2018.12 & 2018.12.1
    Robert
    Thanks for posting this....  getting it reproduced and a case created....
    Stand by for Case #
  • Wed, Feb 6 2019 6:20 PM In reply to
    • Posts 11,124
    • Points 230,130
    Robert...
    Case # 03647258
  • Wed, Feb 6 2019 7:09 PM In reply to
    • Rawb24
    • Posts 13
    • Points 135
    Thank you, Marianna!
  • Wed, Feb 6 2019 8:16 PM In reply to
    • t3chfaith
    • Joined on Tue, Oct 10 2017
    • Posts 42
    • Points 395
    In addition to what Rob mentioned regarding the new grouping feature,
    We also noticed that we are not able to match back to the original master clips on older versions as well. There is also an issue with the timecode not showing up on the timeline. If the group was made the old way it shows TC in older versions of avid. If the Group if it was made in the new grouping method there is no TC in older versions of avid.
    Then we noticed that we are not able to match back to the original master clips on older versions as well.
    Basically what’s happening is that we incorporated the new grouping feature, introduced in version 2018.12.  We then tried opening the groups in an older versions, specifically 2018.09 & 10. We noticed that we lost the capability to toggle through the groups with our mouse, as well as the ability to match back to the original master clips and see timecode.
  • Thu, Feb 7 2019 5:31 PM In reply to
    • Posts 11,124
    • Points 230,130
    Anthony...
    I have support on this - case # 03648103
  • Wed, May 20 2020 2:14 PM In reply to
    • dlogneb
    • Joined on Wed, Aug 27 2014
    • Posts 55
    • Points 530
    Has this been pursued?  I'm just experiencing it now.
    I'm running 2018.9 and am unable to match back from a multigroup created in a later version.   Is there a 2018 version where this has been fixed?
    version 2018.12.3 and the match-back is working fine.   New multigroups are still sluggish thought.
    Avid MC 2018.9.0 Mac Os High Sierra (10.13.6) iMac Pro (2017) 2.3Ghz Intel Xeon W 128 GB 266 Mhz DDR4 Radeon Pro Vega 64 16368 MB [view my complete system specs]
