Editmvp: I'm not sure if it's related, but settings in the command palette are also not saved after restart in version 2018.12. I use shortcut keys for Timeline views, which are setup within the More section of the Command Palette. But the settings are not saved after re-launch. So maybe there's some connection with settings files not being saved properly. I believe the first version with this issue was 2018.11 For me, the only work-around is to re-set my 5 Timeline view assignments in the Command Palette every morning. Which is becoming more and more annoying.
I created a case for this Jack.... 03640681
Stand by
[email protected]
orzels: Same here. Annoying issue with not saved Timeline View assigned to the keyboard. Another thing is not respected Site Settings in any Project created after Site Settings saved. Another one is not saved choosen things in Color Correction windows. After restart there's always default Previous on the left, Main on center and Another clip in the right window. No respect for my settings eg. Waveform on the left and Reference on the right window. I'm afraid there's a lot of bugs, but we don't use them daily. Wish us a lot of patience :) Piotr
Piotr
I created a case for you as well .... 03640687
Support will connect with you and Jack.
marianna
For the record, this appears to be happening again.
AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
I'm experiencing the same issue here, running 2018.12.3 on macOS 10.14.3. Anyone successfully resolved this or have a workaround?
I'm working with an editor on 2018.12.3 and he is having the same issue. He's created a VFX bin that has a variety of Resize pushin effects. They vary from 100%-105% and 100%-110% for example. When he creates the effect it shows both key frames. When he is done for the night, he shuts his system down. The next morning when he uses the effects the 2nd key frame is gone, so all resizes are back to 100%.
Just curious if anyone has had success in finding a solution. I suppose he could just upgrade to a newer version.
Upgrading is the only solution I found.
