Latest post Thu, Oct 10 2019 9:41 PM by Editmvp. 20 replies.
  • Thu, Jan 17 2019 9:05 PM
    • Fish
    • Joined on Sat, Oct 15 2005
    • Filet Post, Halifax NS
    • Posts 589
    • Points 7,365
    2018.12.0 saved effects in bins not keeping keyframes
    I frequently use and re-use little motion effects created in the 3D tool.
    A little creep here. A little pan there.
    It’s nice to be able to drop custom effect on a clip to see if a little move makes the shot work better.
    I do it a lot. I’ve done it for a long time.
    But in the latest release I noticed that the custom effects I make only hold the start keyframe but not the end. Result? Not much of anything.
    Anyone else experience this issue?
    2012 Westmere MacPro 2 x 2.66 GHz 6-Core Intel Xeon) 6 GB 1333 MHz DDR3 ECC ATI Radeon HD 5870 1024 MB As of Jan 2015 - OS X 10.9.5 (13F34) [view my complete system specs]
    AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
  • Fri, Jan 18 2019 2:00 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,932
    • Points 32,390
    Re: 2018.12.0 saved effects in bins not keeping keyframes
    Hi Fish,
        I created a ticket 03634045 and have it investigated by support team.
    RalphC
    MacBook Pro 15 2018 Intel Core i7 2.6GHz Mac 10.15.7 Intel UHD 630. [view my complete system specs]
  • Fri, Jan 18 2019 3:42 PM In reply to
    Just curious...if you're placing an effect that was 10 seconds long on a 1 second clip, the ending keyframes will be well past the end of the clip, thereby not seeing much of an animation.
    Can you confirm that the end keyframes are past your clip by using the scroll wheel in the effect editor?
    I haven't checked this, but it could be a function of whether the effect was saved with keyframes that are "fixed" or "elastic." I know those functions work when trimming a clip; I'm not sure if they affect placing an effect on a clip.
  • Fri, Jan 18 2019 4:14 PM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 155
    • Points 1,900
    I have the same issue with elastic keyframes. Only first frame is saved. More precisely if i drag effect to bin for save it's saved with two keyframes. And I can drag it to next clip and see there all keyframes. But after restarting MC the second keyframe in bin is gone.
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Fri, Jan 18 2019 4:33 PM In reply to
    • Fish
    • Posts 589
    • Points 7,365
    I expected this question. The answer is no. As I said, this behaviour is unusual. Usually a keyframe that adjusts position or scale at the start & end will then apply it to the start and end of any clip I drop it on. That is no longer the case. But even if the second keyframe is not visible, there would still be some motion/alteration of the image over time. Instead, there is only what the 1st keyframe applies and nothing else. Again, unusual.
    The way it used to behave made saving teh effect much more helpful.
  • Fri, Jan 18 2019 4:50 PM In reply to
    I am not seeing that here, although I admit I am testing the next version, so I can't speak directly to 2018.12.
    I take a 3D Warp with start and end keyframes, drop it in a bin, then drag to another clip and both keyframes are in the effect.
    Anyone else on 2018.12 that sees this?
    @Fish, Can you also try a new Avid user?
  • Fri, Jan 18 2019 5:22 PM In reply to
    • Fish
    • Posts 589
    • Points 7,365
    If I drag DIRECTLY from one clip to another, no problem. But if I save the preset to a bin and from the bin drop it on the clip...no second keyframe.
  • Fri, Jan 18 2019 5:25 PM In reply to
    Hmmm... that is odd. In my example above (which wasn't clear) I was dragging it from the bin to the second clip, and it worked.
    Did you get a chance to try a new user?
  • Fri, Jan 18 2019 6:19 PM In reply to
    • gorky
    • Posts 155
    • Points 1,900
    Restart MC and then try with saved before effect.
  • Fri, Jan 18 2019 6:34 PM In reply to
    Still worked for me. The effect from the bin looks exactly as expected.
    Any chance someone could throw one of their effects into a bin, and ZIP the file to post?
  • Fri, Jan 18 2019 6:39 PM In reply to
    • gorky
    • Posts 155
    • Points 1,900
    What MC version are you using?
  • Fri, Jan 18 2019 6:57 PM In reply to
    • gorky
    • Posts 155
    • Points 1,900
    Strange but now all keyframes are saved. But 2 times before on last week they disappeared.
  • Mon, Jan 21 2019 3:55 PM In reply to
    • Editmvp
    • Joined on Wed, Sep 3 2008
    • Billings, Montana
    • Posts 179
    • Points 2,100
    I'm not sure if it's related, but settings in the command palette are also not saved after restart in version 2018.12.  I use shortcut keys for Timeline views, which are setup within the More section of the Command Palette.  But the settings are not saved after re-launch.  So maybe there's some connection with settings files not being saved properly.  I believe the first version with this issue was 2018.11
    For me, the only work-around is to re-set my 5 Timeline view assignments in the Command Palette every morning.  Which is becoming more and more annoying.
    Primary System: Media Composer Ultimate 2024.6 | Avid Artist DNxIO | iMac 2020 i9 10-Core 3.6/128GB/2TB-SSD/Radeon Pro 16GB / OS 14.6.1 | Artist Color... [view my complete system specs]
  • Sun, Jan 27 2019 10:21 PM In reply to
    • orzels
    • Posts 1
    • Points 15
    Same here. Annoying issue with not saved Timeline View assigned to the keyboard. Another thing is not respected Site Settings in any Project created after Site Settings saved.
    Another one is not saved choosen things in Color Correction windows. After restart there's always default Previous on the left, Main on center and Another clip in the right window. No respect for my settings eg. Waveform on the left and Reference on the right window.
    I'm afraid there's a lot of bugs, but we don't use them daily.
    Wish us a lot of patience :)
    Piotr
  • Mon, Jan 28 2019 7:29 PM In reply to
    • Posts 11,984
    • Points 260,645
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    gorky:
    Gorky - you still on OS 10.11.6? or have you updated?  2018.12 min is 10.12.x now
    Sr. Director | Customer Experience and Community [view my complete system specs]
