Latest post Tue, Dec 18 2018 5:46 PM by Telegram!. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Dec 17 2018 1:33 PM
    • Adrian Redmond
    • Joined on Wed, May 28 2014
    • Posts 180
    • Points 2,535
    Being relative new to Avid, I am still perplexed as to the concept of AMA, and am unsure what this is used for, and whether I should be using it.
    So far, I am logging and capturing my raw footage from HDCAM and HDV to bins in the active project, as well as importing the required media assets such as audio fx, voiceovers, graphics etc, into my project from our shared storage. In otherw ords, all of my projects can be accomplished without using AMA (so far).
    But I continually read - in the manuals and in this forum - references to AMA and wonder if there's something I' missing.
    So at the risk of appearing totally ignorant, I ask - can someone tell me what AMA is, and shat it should be used for?
    Avid Media Composer v. 8.5.3. with Symphony Option on HP Z820 Dual Intel E5-2640 6-core HT 2.5GHz CPU 32GB RAM NVidia Quadro K4000 Graphics on Win7x64... [view my complete system specs]
    Adrian Redmond
    Owner / Producer / Editor
  • Mon, Dec 17 2018 2:19 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,786
    • Points 62,285
    Re: AMA
    AMA is a means to link to source footage rather than importing it. When you import footage you are committing to a particular resolution and bitrate. When you AMA link you maintain access to your original source media. You can then transcode your source files to proxy media, edit them into the timeline (faster than working with the AMA linked media in many cases) and then later relink your editing sequence to the original source media in preparation for final render (giving you the maxium quality possible as you render from original source to delivery format).
    This is just one beneficial workflow of AMA. I would say that programs like Resolve and Premiere work like AMA all the time. Avid's distiguishing feature is that it was originally designed to work with media databases and was all about ingesting media into its database (such as when you capture or import). When they developed the parallel workflow of AMA they needed to distinguish it from the original database model.
    I'm sure others will chime in with other attributes of AMA that I have forgotten.
    MC 2020.12 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.3 | Windows 10 Pro x64 (20H2) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, Dec 17 2018 2:30 PM In reply to
    Re: AMA
    [edited to add] Steve beat me! In my defense, my answer is longer. ;)
    AMA stood for "Avid Media Access" and was Avid's fancy name for "link" before they just changed it to "link" in the software.
    For your tape-based material, linking is irrelevant. For any material you already have in a project (music, sound effects, voiceovers, graphics, whatever), it is also irrelevant.
    Where linking might come into play is if you start using material from a file-based camera, or if you're bringing new file-based material into a project.
    For many years, the only way to get file-based material into Media Composer was to "import" it. This would (usually) take a long time, but after the import was finished the resulting Avid media files were the same as media files captured from tapes, i.e. they existed in the Avid MediaFiles folder on your system, so Avid knew exactly where they were, and you were free to move the original material off the system.
    Final Cut and Premeire, on the other hand, could (usually) access material immediately, without the long import step required in Media Composer. Avid created the AMA workflow to address this. With AMA, you could link to file-based media, giving you instant access. The disadvantage with linking is you can't move the original files while Avid is linking to them, or you break the links and the media goes offline. (This also applies to Premeire; I have no idea how FCPX works.)
    To solve that problem, you can link to media and then transcode it ("transcode" is Avid's word for "convert") to whatever resolution you want to work in, creating Avid media files, allowing you to move the original files. In this way you wind up with the same end result as if you'd imported, but because transcoding is a workflow that was added to the software more recently, it takes advantage of newer processor architecture to go much faster than importing.
    So, as far as you're concerned, if you continue to capture footage from tapes, continue to do that as you do now. If you start working with file-based footage, you should consider a workflow where you first link to the footage, and then transcode it to Avid media.
    Media Composer 2020.12 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Mon, Dec 17 2018 8:37 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,786
    • Points 62,285
    Re: AMA
    Plus, your answer is more complete (I rushed mine, lol)
    Steve
  • Mon, Dec 17 2018 10:52 PM In reply to
    Re: AMA
    camoscato:
    AMA is instant on a good CPU.
    Premiere conforms the audio which makes it slower.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Tue, Dec 18 2018 6:46 AM In reply to
    Re: AMA
    George Angeludis:
    I wasn't trying to create a "Premeire v Media Composer" argument; I just wanted to give an idea of the thinking behind Avid's decision to include a linking workflow in Media Composer.
  • Tue, Dec 18 2018 8:03 AM In reply to
    Re: AMA
    Question: Does Linking provide bin data that shows the camera original’s shoot date vs. just the Avid “Creation Date”?
  • Tue, Dec 18 2018 3:15 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,785
    • Points 48,375
      Moderator: MCA Mac
    Re: AMA
    You can right-click in the bin column header and select Choose Columns. One of the choices is Shoot Date. Whether or not that will be filled in is dependent upon the plug-in used to link to the media. You could also try looking at the Aux Timecodes and see if any of them have a date-time timestamp.
    Dave S.
  • Tue, Dec 18 2018 5:44 PM In reply to
    Re: AMA
    camoscato:
    Neither my intention Carl, just facts.
    Desktop PC
  • Tue, Dec 18 2018 5:46 PM In reply to
    Re: AMA
    DStone:
    Thanks so much, Dave. I got used to seeing that Shoot Date field empty with the handful of quicktime Plugin AMA Links, from Drones, and other DSLR (no Aux TC) sources but someday I’ll see it listed and remember your reply.
