Latest post Mon, Nov 26 2018 7:22 PM by Dom Q. Silverio. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Nov 26 2018 12:03 PM
    • Ondrej Azor
    • Joined on Tue, Jun 21 2011
    • Slovenská republika
    • Posts 45
    • Points 565
    DNxIO RGB (444 dual link) capture
    Has anyone captured dual link material with DNxIO succesfully? I am unable to capture 444 HDCAMSR source material using DNxIO box. I see only primary (A) channel displayed on the preview monitor, without complimentary (B) channel colour info. When trying to capture anyway, MC produces an error ("no compatible video detected on video input" or something similar) - so it looks like it IS aware of dual link option with RGB format set (there is no selectable option in Blackmagic control panel for SDI input). When switching to REC709 (422), the video is captured (from A channel only of course), when swithing back to RGB tha capture is not possible (Wrong format video error). I have tried all I could think of, but no luck. There is also no documentation for this workflow, or at least I was not able to find any. The capture/playout of 444 dual link worked flawlessly with NitrisDX...
    DNxIO w. MC2018.11 on HP z820 [view my complete system specs]
    Filed under: , , ,
  • Mon, Nov 26 2018 5:07 PM In reply to
    Re: DNxIO RGB (444 dual link) capture
    Did you set to the Blackmagic Video Desktop to dual link?
    MC 2019.12, W10, Gigabyte X299M, Intel 9940X, Gigabyte 2080Ti Waterforce, 32GB RAM, Samsung 970 EVO M.2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2012... [view my complete system specs]
  • Mon, Nov 26 2018 6:16 PM In reply to
    • Ondrej Azor
    • Posts 45
    • Points 565
    There is no option to set SDI input to dual link - at least not one I can find. The only dual link option is for SDI output, but it has no effect on the capture issue (and it is set to "dual link" anyway).
  • Mon, Nov 26 2018 6:34 PM In reply to
    DNXIO Video Desktop
  • Mon, Nov 26 2018 7:01 PM In reply to
    • Ondrej Azor
    • Posts 45
    • Points 565
    @Dom Q. Silverio - that's what I was referring to, the dual link SDI setting if for output (hence "Video  Output" tab/section). And changing this setting does nothing to SDI input unfortunately...
  • Mon, Nov 26 2018 7:22 PM In reply to
    Ahh.. my mistake.
