Latest post Fri, Nov 8 2019 2:35 PM by BenoitM. 32 replies.
Page 2 of 3 (33 items) < Previous 1 2 3 Next >
  • Wed, Jun 5 2019 3:16 PM In reply to
    Re: Two Avid Generic Plug-Ins competing to link A7s footage
    Marianna,
    Thanks.  I have a case number already but no reply as of yet.
    Avid Media Composer 2018.12 Intel i9 9900K desktop Windows 10 Pro 64GB RAM BlackMagic Design Decklink Mini Monitor Nvidia RTX2080 display card [view my complete system specs]
    Jason Spencer, Director/DP/Editor digitallunchbox.com
  • Wed, Jun 5 2019 3:26 PM In reply to
    • Posts 11,267
    • Points 231,935
    Jason
    They will reply to the one I created - Alek has it now.   03714690
    I also added myself to the case to follow and make sure they deep drill on this one.
  • Wed, Jun 5 2019 4:48 PM In reply to
    Marianna,
    As usual, you are awesome.  Thank you.
  • Wed, Jun 5 2019 4:52 PM In reply to
    • DaveS
    • San Diego, CA
    • Posts 226
    • Points 2,745
    Marianna:
    Dave
    Is this ahppening with you as well?????
    With footage that was linked/transcoded back last fall in 2018.7,8,9 - XAVC import has come a long way. The A7s, even though kind of a consumer camera, is what my client likes to use as a B-Camera so I get to deal with a lot of it.
    With 2018.12.3, the clips link using the Avid Generic Plug-In, and all clips show DF timecode unique to each. One odd characteristic I see but that hasn't caused any problem yet is that the last frame of a previous clip and the first frame of a next clip share the same timecode. This is Source Browser today:
    Avid Generic Plug-In TC frame repeat
    Compare that to footage brought in back in September sometimes with no TC, and 00:00:00:00 NDF TC (NDF is our default) - but most interesting is the duration change from then to now. Not just a frame or two, although I have seen that before as well. Since I rarely have to deal with NDF, if I took the dropped frames into consideration would the difference in calculated duration below check out?
    Avid Generic Plug-In Then & Now
    I haven't done any testing with finished output or generic MP4s like wjasonspencer, all my issues have come from A7s or GoPro FTG.
    Mid 2014 Retina MBP 2.5 i7 w16 GB RAM. Running MC Symphony 2018 with PhraseFind! High Sierra 10.13.6. OWC Thunderbolt dock, 2xSSD Akitio Thunderbolt enclosure... [view my complete system specs]
  • Thu, Jun 6 2019 11:40 AM In reply to
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    This is where premiere kills avid. Relinking in avid sucks
    w10, mc 2020.4, diy x299 7940x [view my complete system specs]
  • Thu, Jun 6 2019 1:20 PM In reply to
    • scocklin
    • Maryland
    • Posts 669
    • Points 8,015
    Have you tried right clicking on the source file and selecting link with?
    HP Z800 2x 3.46GHz Hex Core X5690, 96GB Ram, Windows 10, Samsung SSD 1TB, Avid Mojo DX, Nvidia Quadro K4000, GTX 1080 FTW, DeckLink SDI 4K, Avid MC-2018... [view my complete system specs]
  • Thu, Jun 6 2019 9:03 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,746
    • Points 47,985
      Moderator: MCA Mac
    This is something I reported quite some time ago. Originally, you couldn't link to XAVC-S media. You have to rewrap the media into a QT .MOV file and then use the QuickTime plug-in to ingest it. The rewrap isn't a transcode, and simply replaces the XAVC-S container with a MOV container.
    Then Avid developed the generic plug-in, which could read XAVC-S native. However, there's an off-by-one frame difference between what the generic plug-in would ingest vs. the QuickTime plug-in. Since the the ingest of the same media isn't the same length, you can't relink from QT to XAVC-S.
    I've not checked in quite some time, but if they repaired the generic plug-in, then there could be an off-by-one error with media ingested with the older plug-in, preventing a relink. I'll have to find some older XAVC-S media still on the system, and re-ingest it with the current version of MC and see if the lengths differ.
    Dave S.
  • Fri, Jun 7 2019 5:29 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,746
    • Points 47,985
      Moderator: MCA Mac
    OK, I checked, and the timecode and number of frames are the same. So that's not the problem. However, I too am having problems relinking back to the original media.
    Dave S.
  • Mon, Jun 10 2019 2:03 PM In reply to
    • insch
    • Posts 325
    • Points 3,810
    I'm getting the same issue. I was working on a project on my MacBook Pro. I then opened it on my MacPro using the same external media drive. All the media came up as offline. I created a new bin and linked to each media source folder one at a time. All the media in that new bin linked fine and most of the clips from the rest of the project also linked to that media. But not all. I am having to manually replace the others in my sequence which is very time-consuming.
    I then noticed an issue with plug-ins - the clips that haven't linked are all listed as using the 'Avid Generic 2.6' plug-in whereas all the ones that linked successfully have the 'Avid Generic' plug-in listed. Those versions of the clips are one frame longer than the 'Avid Generic 2.6' plug-in versions of the same clip. They have the same start timecode.
    I am using MC 2018.12.3 and I'm pretty sure the same MC release on my laptop.
    How do I get round this issue? Some of my clips are over an hour long and I have many uses of them in my timeline and it's very laborious editing them in one by one. I have tried different ways of re-linking to the online linked clips, including to 'selected items in all open bins' but to no avail. Very frustrating.
    The footage came from a Panasonic GH5 and a GoPro. Other footage from those cameras relinked fine.
    Thanks Smile
    Mac Pro, 3.7 GHz Quad-core, 32GB RAM, G-Tech G-RAID Studio etc. [view my complete system specs]
  • Mon, Jun 10 2019 8:36 PM In reply to
    • C-King
    • Joined on Tue, Sep 6 2016
    • Posts 36
    • Points 530
    Same problem here, Mac Pro 8 core, High Sierra, went from 2018.9 to 2018.12.5 in hopes of a fix, but no dice.
    Clips are from A7sii
    Try to bring back clips, some link with Avid Generic and have TC, some with Avid Generic 2.6 and have none, duration differs by 1 frame.
    Sequences are broken, random clips offline, and the only thing I can do is match and recut manually. Not great!
    If the "Link Using..." option allowed to specify *which* Generic it used, perhaps that would be a workaround?
    Chyld K.
    MC 2018.3 on 8-Core trashcan Mac Pro, 32GB RAM, 10.11.6, G-RAID Studio XL TB2 RAID MC 2018.3 on tbMPB15, 16GB, 10.12.4 [view my complete system specs]
  • Tue, Jun 11 2019 8:18 AM In reply to
    • 8k
    • Joined on Mon, May 21 2018
    • Posts 2
    • Points 20
    After lots of wasting time - in the finish line of our postpro - i remember the following (please correct me)
    1. there is a different between MCA12.3 and 12.5 - the earlier version shows exact the plugins as all the years - from 12.5 on Avid changed the appearence of the "what plugin" used - the issues: "not recognizing an old plugin used" can be repaired sometimes with the input browser, reload files, change the plugin, etc (but not if a 0.00.00.00 TC appeares)
    2. Avid trys to source out the plugin mess to Nablet - we bought it - it had some other problems, after service it works fine - but cannot solve the old problem of 0.00.00.00 TCs files
    3. As far as the 0.00.00.00 TCs appears(so you forgot to check after ingest - or forgot to give good old tapenames to each SD card) there is no other way - then - go back to the original RAW file - take the first TC of the file and insert it into your recovered files start TC by hand
    dont hammer the Avid service - as we did - they dont answer- there is no solution to offer - we should have taken the handjob as soon as we recognized the problem
    best 8k
  • Tue, Jun 11 2019 10:11 AM In reply to
    • insch
    • Posts 325
    • Points 3,810
    I've also noticed that the timecode of the video and audio of the same clip (in sync) is one frame out when viewing in my Sequence timecode display. This relates to the clips that wouldn't re-link.
  • Wed, Jun 12 2019 6:51 PM In reply to
    FYI - I contacted customer care related to my issues with .mp4's relinking from past projects and today they replied that they are logging this bug under code MCCET-3054.
    I rarely use XAVC-S media so I can't comment about footage coming from a7 cams.  My issues were garden variety mp4 files that varied 1 frame in duration depending on the plugin used.  It's good to see Avid finally logging this as a bug.  Hoping for a quick resolution to this.
  • Wed, Jun 12 2019 7:04 PM In reply to
    • Posts 11,267
    • Points 231,935
    Ping me in a week or so and I can give you an update on the bug.
  • Thu, Nov 7 2019 3:23 AM In reply to
    I'm having the same issue, too (MC 2018-10).
    You know what's even weirder - If you REVEAL FILE on any of the offline clips with "Relink to file" greyed out, the Avid will reveal them in the finder!  Yes, the Avid knows where the clips are but just can't bring it self to link them...
    Oh, and their frame rates have changed - the originals AMAs were 30fps, and the new from the exact same media are 640x360p/30.0061, 1280x720p/30.0246, 1280x720p/30.0245 (It's some archive material for a doco - hence the smaller frame sizes).
    This stops me being able to give them the same tape name to make the relink work, because I need to generate a project for each frame rate (which is impossible) because one can only change Tape names in projects of the same frame rate as the media, of course (not sure why that matters - if I need to modify or repair the tape name, it shouldn't matter the FPS or whether "FILM" is switched on or not - but that's another story)
    Any progress on this? resolved in the 2019 release?
    Jonno
    iMac (27", Late 2013, 3.5 GHz Intel Core i7, 32 GB, OS X 10.12.6) Connected to 27" Thunderbolt Display, BlackMagic UltraStudio Express (10.7... [view my complete system specs]
    www.fusspotfilms.com
