AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
Did you happen to try to create a custom project with the size needed to see if that makes a difference?
Sorry...should ahave mentioned, it IS a custome project size.
And the composer windows are vertical (so, good.)
The only road block is interpreting the footage.
I got mine working.
My test was to make a 1080x1920 project
AMA link a 1920X1080 video.
The trick was changing the Frame aspect ration in the lower frameflex box to 9:16 then stretching out the frameflex frame in the RH preview. Worked fine.
Broadcast & Post Production Consultant / Trainer Avid Certified Instructor VET
RH preview? I've changed the ratio. But the stretching part does not work it won't let me change the ratio of the box it applies. only smaller or larger.
It really should be simpler than this.
Hello Fish, did you get an answer, how to manage vertical footage filmed in 1080 x 1920? In version 2019.12 this could be done, but don´t ask me how. I have updated today to 2020.4, because the "Whats New" text showed some improvements on this topic, but....my 1080 x 1920 project then started with an "exeption" error, til I deleted my 2019.12 "frameflexed" footage from the sequence. I tried some things out, but I didn´t get it right without strange resizing. Does someone know a nice workflow? The aim is to import, edit and export 1080 x 1920 footage in a 1080 x 1920 project..and it doesn't matter if the playout monitor presents it correctly.
Thx Armin
