Latest post Tue, Sep 4 2018 7:08 PM by RedArrowRyan. 2 replies.
  • Tue, Sep 4 2018 2:33 AM
    • CN1990
    • Joined on Tue, Sep 4 2018
    • Posts 1
    • Points 25
    Export File progress bar resets each time it completes
    Hello:
    Can't seem to export. Might be an issue with the multipass option, but I can't disable to from any menu or screen I can find. Sequence is about an hour long, being published at the fastest setting using h264 codec. Using the most recent version for windows.
  • Tue, Sep 4 2018 11:32 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,810
    • Points 48,870
      Moderator: MCA Mac
    Re: Export File progress bar resets each time it completes
    Greetings, and welcome to the forums.
    I'm afraid we're going to need a bit more information. First, what are your system specifications (you can see an example by looking at mine at the bottom of this post). Next, what is the project format (HD, UHD, etc.) , the format of the media (e.g. MXF OP1A, MP4 in a .MOV container, etc.) and the paramters from the export dialog. Also, any error or informational messages produced.
    Dave S.
  • Tue, Sep 4 2018 7:08 PM In reply to
    Are you usuing Media Composer First?  If so, it seems to default to Multi-pass export and you can't turn it off. Either suffer the equivalent of 4 exports (progress bar going to 100 four times) or export as DNxHD (which only takes one pass) and then convert to H264 outside of Media Composer First.
    Follow me at www.twitter.com/redarrowryan [view my complete system specs]
