Latest post Wed, Sep 30 2020 6:31 PM by Gchawl93. 17 replies.
  • Fri, Aug 17 2018 1:38 AM
    • mbmpost
    • Joined on Thu, Apr 13 2006
    • Alexandria, VA
    • Posts 46
    • Points 570
    10.13.6 2018.8 and network drive project save error
    I just updated to latest high sierra and mc and am having problems saving the project to a network drive. Prior to the update, no problems. I can save to internal drive as well as direct connected drives. Thoughts?
    3.7 Quad core Xeon E5 trashcan 32GB ram. Sierra OS. 10Gb san link 2. Qnap shared storage. MC 2018.8 symphony option. 2012 15-in macbook pro 16GB ram. OWC... [view my complete system specs]
  • Fri, Aug 17 2018 5:58 PM In reply to
    • Posts 11,540
    • Points 254,905
    Re: 10.13.6 2018.8 and network drive project save error
    Have you tried Mac Repair permissions?
    Then make sure the user permissions are Read and Write.
    Then rebuild the databases.
  • Thu, Sep 13 2018 2:10 PM In reply to
    • mbmpost
    • Alexandria, VA
    • Posts 46
    • Points 570
    Hey Marianna,
    I did all you recommended but no joy. The odd thing is that all the bins save fine to the network dirve, just not the project file. I thought it was the newest avid software, but I also have high sierra installed on my laptop running the last version 8.9.3? before the naming convention switch. Upon opening the project, a warning message comes up straight away and says I will not be able to save project. Very odd. Thoughts?
    Brennan
  • Mon, Oct 1 2018 2:23 PM In reply to
    • mbmpost
    • Alexandria, VA
    • Posts 46
    • Points 570
    UPDATE:
    I did a clean install of the High Sierra OS 10.13.1. I then did a clean install of MC 8.9.3. (my latest version 2018.9 does the same thing as 8.9.3, I just happen to have a dongle for that one which makes it easier to check different processes) I then tried opening up a project from multiple network drives and none would save the project file, but had no problems saving bins, or anything else. I rebuild permissions from the terminal, I have tried everything the interwebs had to offer. Is no one else having a problem like this? I know its not just my NAS failing to save, its every drive I mount on a network. My network is not complicated...its all mac and all the machines are streamlined for thier particular purpose, ie not a lot of extraneous stuff installed. I would appreciate any help at this point. I can not be the only one....
    Brennan
  • Mon, Oct 1 2018 3:20 PM In reply to
    Have you tried a new project?
  • Mon, Oct 1 2018 3:32 PM In reply to
    • mbmpost
    • Alexandria, VA
    • Posts 46
    • Points 570
    KK,
    Yup. New project, new settings, same results. I am baffled. The exact same setup works flawlessly in 10.12.6.
    Thanks for the response.
    Brennan
  • Mon, Oct 1 2018 3:43 PM In reply to
    Are you working in a Unity/NEXIS-Like environment? Or just using the NAS as external storage?
    One way to tell is if there are subfolders in your project folder for each system that's accessed the project (and, a corresponding AVP file in the system folder).
  • Mon, Oct 1 2018 4:00 PM In reply to
    • mbmpost
    • Alexandria, VA
    • Posts 46
    • Points 570
    KK,
    I use my NAS in both situations. Sometimes I do project sharing with indiestor's mimiq (fantastic) and sometimes I just use it for shared storage. For my tests, I have tried both configurations with the exact same result. To reiterate, I have used both configurations flawlessly in 10.12.6. I'm attaching the error message I get.
  • Mon, Oct 1 2018 4:06 PM In reply to
    And just to confirm, you're seeing this both in 8.9.3 (the screen shot above) AND 2018.8/9?
  • Mon, Oct 1 2018 6:49 PM In reply to
    • radrattus
    • Joined on Wed, May 9 2018
    • Posts 27
    • Points 335
    Mac based Media Composer has done this for as long as I can remember when using SMB based shares. It's fairly normal.
    Certain third parties, such as Editshare, used to advise folks to install Thursby Dave as a fix. Later they found another solution.
    For what it's worth you can normally work around this issue by saving projects to NFS based mounts. That doesn't cost a bean.
    The bottom line is that the gold standard for working on a network is NEXIS. If you’re using third party storage talk to the vendor, they might have a fix Geeked
  • Mon, Oct 1 2018 7:44 PM In reply to
    • Posts 11,540
    • Points 254,905
    radrattus is spot on....
    Also... one other thing to check.  Check your Mac Sharing name. On the Mac desktop go to..
    Apple Menu > System Preferences > Sharing
    The Mac sharing name will appear at the top of the page.  Make sure the name is less than 15 characters, has no spaces, or special characters (! @ # $ % ^ & * ( ) _+ ? : " > < , . ' ; ~ `).
  • Thu, Nov 14 2019 6:26 AM In reply to
    • goodBoy
    • Joined on Thu, Oct 24 2019
    • Posts 59
    • Points 695
    radrattus:
    I'm having exactly the same issue on MC 2019.9, but I'm using AFP to connect to a QNAP NAS. I just save my projects on my system drive, but it's not ideal.
    iMac Pro, 3.2 GHz Intel Xeon W, 32 GB RAM, Radeon Pro Vega 56 8GB, QNAP NAS connected by Thunderbolt, OS 10.14.6 [view my complete system specs]
  • Fri, Sep 18 2020 8:37 PM In reply to
    • Gchawl93
    • Joined on Fri, Sep 18 2020
    • Posts 2
    • Points 20
    Also having this issue with MC 2020.8 on a QNAP NAS over SMB and AFP. Works fine on my windows machine, but my Mac running Mojave 10.14.6 won't save.
  • Wed, Sep 30 2020 6:48 AM In reply to
    • goodBoy
    • Posts 59
    • Points 695
    I've been in contact with both QNAP and Avid support about this issue, since I've been unable to get projects to save using any network protocol. QNAP says that Avid must change their file handling behaviour, and then Avid says that it's QNAP's fault for not supporting the protocol. I blame QNAP more since they advertise on their website that they actually support Avid Media Composer. They tell me they are now going to remove this information from the website! Doesn't help me too much.
    Avid also recommends looking on forums for hacked workarounds, but obviously they cannot provide support for this. Has anyone had any success with a 3rd party software solution?
  • Wed, Sep 30 2020 9:11 AM In reply to
    • radrattus
    • Posts 27
    • Points 335
    This behavior has been there for years on Mac.
    Thursby Dave used to be one way to solve the issue, but that is now EOL.
    Other possible solutions...
    If you HAVE to save projects on the network, try connecting to the QNAP over NFS > this should solve the issue Smile
    That said, if you are working standalone, saving projects locally will be much faster anyway. You can still use network storage for media via "alldrives".
    There are third party solutions that work well, but it sounds like you don't need to buy anything.
    Hope this is helpful.
