Latest post Sat, May 12 2018 8:32 PM by George Angeludis. 5 replies.
Page 1 of 1 (6 items)
  • Tue, May 8 2018 8:07 PM
    losing my LUTZ's
    hello,  on a long form documentary. the footage has been linked and then transcoded from a Panasonic AG-DVX200 camera to MXF175. I've been viewing and assembling for a few weeks, and have been applying a LUT to all footage on a bin by bin basis, basically using one of three LUT's, the Canon C-Log to rec 706, Vlog to 709 for DVX200, or Vlog to 709 for DVX 35. My footage is in my seperate location shoot bins, and I make a seperate bin for each locations' sequences.  Yesterday whenever I'd edit a shot, the clip would land in the sequences timeline, the LUT would disappear, ie the shot would revert to flat in the rec monitor, and a copy of the original clip would appear in my sequence bin, with no LUT.
    This is now happening in all my bins.
    extrmely frustrating .... restart reboot all to no avail.
    So far my system has been very stable, and I have not installed or updayed eny software.
    Any help/ideas appreciated
    Avid & FCP editor, now installing A Fractal Intel 4 core 4.5Ghz, Windows 10, Avid 2019.12 new install, BlackMagic Decklink 4k studio card Migrating... [view my complete system specs]
    Yo, let's get this done, and then go outside and play
    Filed under: ,
  • Wed, May 9 2018 6:31 PM In reply to
    Re: losing my LUTZ's
    So you applied the LUT as a CC effect and not "baked" in through source settings before the transcode.
    So it's easy to re apply the LUT.
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Wed, May 9 2018 9:20 PM In reply to
    hello George,
    no I applied the LUTs through the source setting window. then apply all
    it's the, it worked before and now it won't that's a bother
  • Fri, May 11 2018 6:30 PM In reply to
    I don't understand.
    If you "baked" the LUT while transconding the transcoded clips (new media) will have the LUT as part of the new files.
    Desktop PC
  • Fri, May 11 2018 6:44 PM In reply to
    The workflow was
    link via AMA,
    transcode to DNX no LUT,
    I'm applying the LUT per bin through Source Settings
    what is happening is as soon as I splice a clip on a timelien,
    1) the clip gets copied to my sequences bin, which I'd never seen before,
    2) the clip looses it's LUT.
    and if I try to match fram, it will match to the non LUT clip in the sequence bin and not to the clip in the footage bin I
    edited it from.
  • Sat, May 12 2018 8:32 PM In reply to
    I have never worked like that.
    I have abandoned LUTs myself but when I did I treat them as CC effects, saved and used at clips
    NOT at source settings which is for Linked clips not transcoded.
    Try to refresh the adapters.
    Save the LUTs and apply them to clips.
    It's logical to match frame te original clips as the LUTs applied to source settings are not part of the clips.
    Desktop PC
