Latest post Tue, Oct 8 2019 9:30 AM by nigelpedwards. 10 replies.
Page 1 of 1 (11 items)
  • Tue, Apr 10 2018 12:28 PM
    • henrikhu
    • Joined on Tue, Apr 10 2018
    • Posts 3
    • Points 35
    How do I motion track text using NewBlue Titler Pro
    I am working on an 8K project, and had to install NewBlue Titler Pro (as title tool currently is not working in 8K). I have added a text message-text to the screen, and I want the text to track to the motion of the cell phone:
    I have tried:
    * To find a tracking tool in NewBlue Titler Pro
    * To add effects (resize/3D warp) in Avid to the Titler Pro-title
    * Google/youtube/avid forum search
    Any suggestions would be very much appreciated. This is also my first post in the forum, and I hope have posted in the right thread.
    iMac Retina, (Retina 5K, 27 inch, late 2015) OS X El Capitan 4 GHz Intel Core i7 16 GB 1867 MHz DDR3 AMD Radeon R9 M395 2048 MB [view my complete system specs]
  • Wed, Oct 2 2019 8:23 AM In reply to
    Re: How do I motion track text using NewBlue Titler Pro
    I would also like to be able to motion track a NewBlue Titler title, however I don't think it includes any motion tracking. You can move images between two keyframes, and that might be okay for some simple tracking instances, but not in all cases.
    I haven't tried it, but I wondered if the only way may be to create your NewBlue title against a green screen, mix it down and then apply a chromakey along with the usual Avid motion tracking.
    I see this was April last year, did you manage to achieve what you wanted?
  • Wed, Oct 2 2019 3:01 PM In reply to
    • henrikhu
    • Posts 3
    • Points 35
    Hi Nigel, and thanks for your input. The shot was cut before i had to figure out. Will update here if i find solution.
    -Henrik
  • Thu, Oct 3 2019 1:34 PM In reply to
    Thanks for responding Henrik. I've been in touch with NewBlue and they replied to say "We do not currently have a motion tracking feature.  Thank you for the suggestion though."
    If I find a workaround I'll be sure to post it here.
  • Mon, Oct 7 2019 7:18 AM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 193
    • Points 2,330
    Import the text as a png and track that?
    MAC OS X 10.11.6 AVID MC 2018.3 + Avid Mbox Pro 3 MACBOOKPRO 15" Retina, i7 2.66 GHz Quadcore, 16GB Ram Dell UltraSharp U2711 Sony FS5 & Alpha... [view my complete system specs]
    Honestly I hate editing.
  • Mon, Oct 7 2019 9:33 AM In reply to
    • henrikhu
    • Posts 3
    • Points 35
    That is an option - albeit a more complicated one than I had hoped for :)
  • Mon, Oct 7 2019 10:37 AM In reply to
    Thanks for your comment Addinski.
    A PNG file would just be a static image though wouldn't it? One of the best things about Titler Pro titles is the powerful animation that can be applied, and certainly in my case I need to motion track an animated title.
    A little bit of digging reveals that there is such a thing as an APNG file - Animated Portable Network Graphics. However I doubt that Titler Pro can output such a file unfortunatly. I'm not sure whether Avid would be able to import an APNG file either.
  • Tue, Oct 8 2019 7:37 AM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 193
    • Points 2,330
    Ok, then render the animation, export that incl. alpha via QUICKTIME DNxHR (or try video mixdown), then reimport and track that video?
    good luck.
    Andre.
  • Tue, Oct 8 2019 8:06 AM In reply to
    Thanks Andre. I'm fairly sure that a mixdown would lose the alpha, an export to DNxHR sounds like it could work though, however I can't see any option in Avid MC's File > Output > Export to file, do you know for sure that this is possible?
  • Tue, Oct 8 2019 9:18 AM In reply to
    • addinski
    • Erfurt, Germany
    • Posts 193
    • Points 2,330
    I only have mc 8.3. Since 8.4 exporting with alpha via DNXHR should be possible. Use quicktime and the choose the appropriate codec...
  • Tue, Oct 8 2019 9:30 AM In reply to
    Hmmm...yes...there's a "Send to QT Movie", and it's possible to change the settings where DNxHD and DNxHR are available, this may just work Smile
    I'll give it a go (though sadly not for a few days).
