Latest post Fri, Apr 6 2018 1:52 AM by Telegram!. 4 replies.
  • Fri, Mar 30 2018 10:09 AM
    • Tim
    • Joined on Mon, Sep 12 2016
    • Posts 29
    • Points 315
    Daytime timecode + slowmotion + autosequence workflow
    Hi guys,
    I was wondering if any of you have a workflow for this particular situation. For a small production wildlife show our cameraman is daytime TC locked to our soundguy. If we switch between slowmotion shots and normal shots we get TC overlap / breaks, because the slomo clip is stretched out and longer than realtime. Camera TC basically goes 'back in time' whenever he syncs back to our soundguy for normal speed recording. This becomes quite confusing in post trying to sync video and audio using autosequence.
    Any advice is welcome, thanks.
    AVID MC 2020.12 / Blackmagic Intensity Pro 4K / Intel Core i7-7700K @ 4.2ghz / 64GB ram / GeForce RTX 2080 Ti / Windows 10 pro / [view my complete system specs]
  • Fri, Mar 30 2018 2:06 PM In reply to
    • gumbaedit
    • Richmond, VA
    • Posts 527
    • Points 7,000
    Re: Daytime timecode + slowmotion + autosequence workflow
    Why are you using autosequence to sync?  Why not identify which shots are are regular speed and use autosync using timecode to sync just those?
    6 core Late 2013 MacPro 3.0 gHz, 16 gigs RAM, MC 8.8.5 on OSX 10.12.4, DNxIO, Flanders CM250, BMD Desktop Video version 10.9.1 [view my complete system specs]
  • Wed, Apr 4 2018 10:09 AM In reply to
    • Tim
    • Posts 29
    • Points 315
    From viewing the bin, there is no way in telling which clips are slomo because they're saved as 25 fps clips. (camera sony f5). Because we have a lot of raw material and unfortunately no people logging I have yet to find a proper workflow for this. I have suggested switching the TC to 00:00:00:00 just for the slomo shots so that I can identify them easier (we dont record audio during slomo).
  • Thu, Apr 5 2018 11:22 PM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,433
    • Points 98,200
    The problem that I see with doing that is that inevitably they'll switch to slo-mo/00:00:00:00 and forget to switch the timecode back.  I think that you'll just be exchanging one problem for another.  What I would be more inclined to do is live with what they're currently doing, but change the reel ID on the slomo media after you ingest it.  That way you won't get caught with duplicate or reverse timecodes.
  • Fri, Apr 6 2018 1:52 AM In reply to
    How about a 2-Video track Auto-Sequence? You isolate the Slomos and AutoSequence them separately. Then add on V2 to other AutoSequence on V1.
    You can maybe experiment with adding a real-time Timewarp speedup. Maybe it works...?
    When editing from this two-track Auto Sequence, you use matchframe first on the Slomo Clips, (which you could of course Color ds.ifferently from the normal speed shots).
    i’m doing something like this now on double system film xfers and problem ematic wav files that don’t quite match.
