Latest post Thu, Feb 22 2018 12:55 AM by DStone. 2 replies.
  • Wed, Feb 21 2018 10:39 PM
    Mushrooming files on import!
    Hi, I'm currently importing mp4 files into Avid and for some reason they're taking up a HUGE amount of space (much larger than the original files).  What's going on here?  I'm concerned that I may run out of computer space.  In addition, once I've created a timeline and  after rendering special effects, if it's a huge file, how do I export it?  I think it would be too big for even a DVD.  Help please!
    Filed under: , ,
  • Wed, Feb 21 2018 10:56 PM In reply to
    Re: Mushrooming files on import!
    Debra66@aol.com:
    What format/frame rate are the mp4 files, what format/frame rate is your project, and what resolution are you using when you import?
    Debra66@aol.com:
    How long is the sequence?
    Media Composer 2021.6 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Blackmagic UltraStudio Mini... [view my complete system specs]
  • Thu, Feb 22 2018 12:55 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,794
    • Points 48,720
      Moderator: MCA Mac
    When you import, the MP4s are transcoded to DNxHD (or DNxHR, depending on the project settings). These are far less compressed and so take up a lot more space. Linking to the MP4s uses the files natively; no transcoding required. But playback performance may suffer, depending on exactly which format of MP4 was used (if you're forced to use the QuickTime plug-in, performance suffers).
    Dave S.
