Latest post Mon, Dec 9 2019 1:32 PM by campebejo. 14 replies.
Page 1 of 1 (15 items)
  • Sat, Feb 10 2018 5:27 PM
    • Turnstile
    • Joined on Sat, Feb 10 2018
    • Posts 3
    • Points 65
    How do I extend an audio clip past its original parameters?
    Situation: So I've added some reverb to a gunshot sound to make it "ring out" more.
                     The original sound effect is only 2 seconds long.
    Problem: Because I added reverb to it, the echo lasts well beyond this 2 second window and is cut off abruptly.
                   After some web searching and consulting my avid textbook, I was unsuccessful in finding out how to extend this audio clip  enough to capture the reverb I've added.
    Any help would be greatly appreciated.
    - Ben
  • Sat, Feb 10 2018 7:03 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 948
    • Points 12,125
    Re: How do I extend an audio clip past its original parameters?
    I would seperate audio from video, and work on audio first. Save your current reverb. Then take the original sound and apply audio effect "Time Compression/expansion", and expand the current audio fileto the same length as the reverb effect langth.
    When this composition works as desired, continue with the video part. Apply the timewarp effect to expand the video to the sm lngth as the new audio.
    Finally, put both parts together on a timeline, and then make an export - and re-impodt the exported clip.
    May be this helps.
    Joachim
    Joachim Claus
  • Sat, Feb 10 2018 7:27 PM In reply to
    Turnstile:
    - Ben
    There's probably better ways to do it, but I would Add an RTAS-enabled track below the original, copy the last bit of dry sound onto the RTAS track using the reverb setting of choice.
    Make sure you have plenty of time available past that moment on the RTAS track.
  • Sat, Feb 10 2018 7:32 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,439
    • Points 17,745
    For a two second sound effect, I would probably just put it in a sequence clean, isolate it and do an audio mixdown adding a few seconds of blank tail.  Cut in the new media and add the effect to that.
  • Sun, Feb 11 2018 12:07 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 8,411
    • Points 97,300
    smrpix:
    Me too!  In fact it's what I invariably do with any audio that has a hard cut off that I need to add reverb to.  If there's significant atmos present, fade the end of the audio over a few frames before doing the mixdown.  With an effect this short it's unlikely that this will even be necessary though.
  • Sun, Feb 11 2018 8:39 AM In reply to
    • Turnstile
    • Posts 3
    • Points 65
    This sounds like the most logical solution and what I was looking for, it makes perfect sense to me.
    Though in the "audio mixdown" interface I don't see an option to create a blank tail.
    The parameters of the audio length are set.
  • Sun, Feb 11 2018 9:55 AM In reply to
    Cut the sound effect into a new sequence. Add the effect a second time so you now have the effect twice. Set the audio gain of the second clip to infinitiy (mute) then mixdown. You now have a clip with the effect followed by silence of the same duration.
  • Sun, Feb 11 2018 2:09 PM In reply to
    • smrpix
    • Posts 1,439
    • Points 17,745
    Not sure I described it properly.  Set the in and out points like this to include filler in the mixdown:
  • Sun, Feb 11 2018 3:47 PM In reply to
     and this is the RTAS version.
  • Sun, Feb 11 2018 10:48 PM In reply to
    One way. With the required clip into a new timeline use Add Edit to cut the clip 1 frame from the end.
    Insert edit X seconds of filler at the add edit point to extend the timeline out beyond where it is needed.
    Go back to the clip and trim it 1 frame forward so the clip is back to the original length.
    Mark in at the start of the timeline and Mark Out at the end of the timeline.
    Make an audio mixdown using the Mark In to Mark out to set the mixdown's duration.
    FWIW I would name and keep this timeline so I could remake the lengthend clip with a different Reverb decay rate if required later.
  • Mon, Feb 12 2018 1:10 AM In reply to
    • Turnstile
    • Posts 3
    • Points 65
    Pat Horridge:
    This worked great!
    Thanks for your suggestion.
    - Ben
  • Fri, Dec 6 2019 3:22 PM In reply to
    • campebejo
    • Joined on Thu, Sep 20 2018
    • Sweden
    • Posts 34
    • Points 315
    Have been reading this thread,
    Doesn't one of the suggested fix's here - to do an audiomixdown of the short audio clip to create more space for the tail of the effect - create problems down the line for people conforming stuff over to the Audio Mixer (i.e. when the offline stage is complete).
    Just wondering if it's ever really a good idea to be using audio or video mixdowns in your workflow, given that it breaks the link to the source media?
    Anyone out there? :D
    I guess the RTAS solution would be an alternative then. But not super convnient to be creating a new audio track for every clip you would like to apply a unique effect to.
  • Fri, Dec 6 2019 6:07 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,184
    • Points 23,370
    I agree bounce the track add fx there and mix in
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Mon, Dec 9 2019 1:08 PM In reply to
    • Cutyes
    • Joined on Sat, Jan 14 2012
    • Berlin
    • Posts 166
    • Points 2,165
    campebejo:
    If you want conforming to have the original media then just leave the original media in the timeline, too, and pass both, original and mixdown, on to conforming. That is, of course, parallel on separate tracks.
  • Mon, Dec 9 2019 1:32 PM In reply to
    • campebejo
    • Sweden
    • Posts 34
    • Points 315
    Ah yeah, that makes sense!
    Thanks for the tip! :)
