Latest post Mon, Apr 20 2020 6:11 PM by Ryan Johnson. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Jan 29 2018 9:59 AM
    • nigelad
    • London UK
    • Posts 560
    • Points 6,515
      Avid Certified User
    AJA T-tap
    Hello to any AJA T-tap users out there!
    I am testing one out with an LG OLED55B6  TV. It seems to work ok and avoids the problems we had with a BM device [below].
    I get a green matrix screen whenever I launch MC [v8.6.1] which clears when the app is open. I also occasionally get a "incorrect format" warning from the TV on launching MC. A reboot fixes this.
    Is anybody else seeing these issues?
    I'm trying the T-tap because we have problems with our BM mini-monitors feeding these 4K LG OLED tvs. After a couple of hours a white a line and/or white 'sparkling'  appears on the left of the tv. I swapped out mini-monitors and had the same problem - but they are fine with Toshiba 1080p tvs.
    Nigel
    ISIS 5500, MC 18.12.7 & PT 18.12 on Mac OS 10.12.6 & 10.13.6 with BMD Mini-Monitors, UltraStudio 4K and AJA T-taps. [view my complete system specs]
  • Tue, Aug 6 2019 7:28 PM In reply to
    Re: AJA T-tap
    My T Tap works fine with MC 2019.  BUT, it still crashes on quit.  Remove T Tap and quit is normal
    Mac Pro (late 2013) 3.5 GHz 6-core E5 32 DDR3 OS 10.14.5 MC 2019.7 [view my complete system specs]
  • Tue, Aug 6 2019 7:34 PM In reply to
    • Posts 11,531
    • Points 235,135
    Re: AJA T-tap
    Castlegatemedia:
    What driver version are you on?
    They have a new driver version
    AJA Software Installer v15.2.2 - Mac
    https://www.aja.com/products/t-tap#support
    marianna
  • Wed, Apr 15 2020 11:58 PM In reply to
    • rcooper
    • Posts 95
    • Points 1,395
    Re: AJA T-tap
    When playing media with the toggle hardware button activated, I only get audio from the monitor plugged into the AJA T-TAP. I cant get audio out of the sound card and into my mixing board. When I disable the hardware button, of course I lose the video feed to the TTAP monitor, but the audio returns via sound card.
    Is there a way to display video on the TTAP monitor and audio through my sound card?
    MAC pro OS 10.6.8, 5GB RAM, 2.66 quad core Xeon, MC vers. 5.5.3, nvidia Gforce GT120, LG DVI-D monitors, matrox mini [view my complete system specs]
  • Thu, Apr 16 2020 5:09 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,541
    • Points 64,320
      Moderator: MCA Mac
    Re: AJA T-tap
    Nope.  Avid will always send audio to the i/o device if there is one connected.  You can feed the audio board with decoded audio from the monitor or using an external HDMI or SDI de-embeder.
  • Mon, Apr 20 2020 6:11 PM In reply to
    • Ryan Johnson
    • Joined on Tue, Dec 12 2006
    • New York, NY
    • Posts 55
    • Points 700
    Re: AJA T-tap
    This is true, however I think it would be very helpful if Avid offered the ability to route audio separately from video.
    FYI, the NDI Open_IO plugin (previously included by default with MC) includes the ability to “Play local audio when broadcasting.” A similar feature for hardware Open IO (AJA, Blackmagic) would be useful in certain scenarios... Using headphones while sending video via HDMI to a TV for example.
    Getting an analog audio output from existing hardware IO devices is a hassle- Neither the AJA T-TAP or Blackmagic MiniMonitor offer this. A de-embedder is ceratinly an option, but it's more devices, cables, power supplies to carry and manage.
    My two cents.
    -Ryan
    iMacs, MacPro's, OSX 10.14.6, MC 2019.12, Nexis 2019.12 [view my complete system specs]
