Latest post Tue, Feb 12 2019 11:10 PM by editor14. 4 replies.
  • Tue, Jan 9 2018 12:49 AM
    • editor14
    • Joined on Thu, Mar 17 2011
    • Posts 29
    • Points 315
    MXF OP1a Closed GOP
    Hi All,
    Can someone please explain how to export this type of OP1a out of MC?
    XDCAM HD422 @ 1080i 50Mb/s 12 frame Long GOP Format settings, GOP: M=3 N=12 GOP: Closed
    I can find any place to edit these settings on the default XDCAM op1a export setting.
    Cheers
    Bob
  • Tue, Jan 9 2018 3:47 PM In reply to
    • derDoyle
    • Joined on Tue, Aug 18 2015
    • Berlin, Germany
    • Posts 136
    • Points 1,645
    Re: MXF OP1a Closed GOP
    You can't edit these settings because they are set to this per default.
    Just export as XDCAM MXF OP1a from the standard export dialog. Your project must be 1080i of course.
    If you open the resulting file in MediaInfo you will see that everything is fine :)
    Clients: MacPro6.1 (2013 "Trashcan"), 3,5GHz 6-Core, 16GB (1866) RAM, AMD FirePro D500, 256GB SSD, macOS 10.14.6, Avid MediaComposer 2018.12... [view my complete system specs]
    Passionate In-House Avid Support
    Admin of the German Avid Community on Facebook
  • Mon, Feb 11 2019 5:49 AM In reply to
    • N Ryan
    • Joined on Thu, Jul 3 2014
    • Melbourne, Australia
    • Posts 93
    • Points 1,145
    I've had some  XDCAM mxf delivery files which were made from Media Composer 8.6.3, have been rejected from the client as they are not Closed GOP.
    I had the export option “Re-encode for XDCAM bitstream compliance” checked.
    My report says:
    GOP Status: Closed Open [1  Errors; Reason: 'GOP Status' is not Closed]
    GOP structure: {GOP(s): [(1-3, 7, 0.0 %), (1-3, 10, 0.0 %), (3, 12, 99.9 %)], Average GOP Length: 12}
    Everything else in the report was correct.
    If I can't alter the export settings, how do I make Closed GOP XDCAM mxfs?
    Media Composer 8.8.5.46340 with Symphony HP Z6 G4 Workstation 32.00 GB RAM Intel(R) Xeon(R) Silver 4116 CPU @ 2.10GHz BCC 12.0.4 Avid ISIS & Nexus [view my complete system specs]
    Neil.
  • Tue, Feb 12 2019 9:32 PM In reply to
    • bucur.marian
    • Romania
    • Posts 99
    • Points 1,250
    I also have a customer complaining about the GOP STATUS, and I've tried to export it from MC 2018.12.1, using different settings.
    No luck, MediaInfo reports Open GOP for all the files exported.
    Whatever the customer has :) [view my complete system specs]
    ACSR Elite
  • Tue, Feb 12 2019 11:10 PM In reply to
    • editor14
    • Posts 29
    • Points 315
    An OP1a MXF out of Avid does not encode the file with Closed GOP.
    The only way to do it is use a third party encoder. The cheapest option is unfortuntunaly Adobe Media Encoder. It has Advanced MXF options - I click the 'Force Closed GOP' setting and encode.
    My method is to create a video mixdown of master seq. to either ProRes or DNx. Make timeline with just mixdown and master audio, then export same as source into a .mov container. Then load into Media Encoder.
    The sooner mastering interlaced dies a quick death the better. IMHO.
