Latest post Thu, Jan 25 2018 5:59 PM by rodpaul. 16 replies.
  • Fri, Dec 15 2017 5:44 PM
    • rodpaul
    • Posts 103
    • Points 1,390
    Resizing composer Window 8.9.4
    Not sure what the issue was with mixed monitors in earlier versions as I had mixed an HD res 24" with a 4K LG 34" and had been able to drag the app across both monitors and then resize the composer and timeline windows in the LG to my liking. Both monitorsd at 100% scaling in Windows 10 and I can read everything fine anyway. In 8.9.4 the app fills both monitors as before, but I can't alter the size of the composer window any more. It's too small now. Anyone know a workaround?
    Dell T3600T 12 Cores 3.5 ghz Intel 32GRAM K4200 Windows 10 [view my complete system specs]
  • Fri, Dec 15 2017 8:44 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,779
    • Points 48,295
      Moderator: MCA Mac
    Re: Resizing composer Window 8.9.4
    It would be helpful if you would post your current system specifications, video card, etc. Unless you really are running on an HP 8600 with 4Gb under Vista 64. Stick out tongue
    Dave S.
  • Fri, Dec 15 2017 9:45 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    Good point. 8600 left some time ago..
    Thanks -
  • Sat, Dec 16 2017 4:01 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,779
    • Points 48,295
      Moderator: MCA Mac
    What driver for the quadro are you using?
    Dave S.
  • Tue, Dec 19 2017 11:01 AM In reply to
    • ZFigas
    • Joined on Tue, Jan 31 2006
    • Poland
    • Posts 122
    • Points 1,655
    Rodpaul, I apologize but it is disrespectful, you start the post and the end.
    I unfortunately have a similar problem, the NVidia K5200 (driver 385.87), the Eizo CG318 monitor and I can barely see anything. scaling in Windows does not solve anything. if it scales 149%, the fonts are too small and if 150% is Avid, it switches to 640x480. if you edit a plug in Boris BCC, fonts are 1 mm size.
    Any problem with Adobe, NewBlue.
    Regards
    Zb.
    HP Z8 G4, 2xXeon-6246R, 128 GB RAM, Win 10 Ultimate, MC 2020.8, Nvidia Quadro RTX 4000, Boris Red 5.6, BCC 13.5.1, Saphire 11.0.2 Adobe CC, TMPGenc [view my complete system specs]
  • Wed, Dec 20 2017 11:04 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    It is a bug in 8.9.4. Roll back to 8.9.3 and wait for Avid to fix it in the next patch.
  • Wed, Dec 20 2017 11:20 PM In reply to
    • ZFigas
    • Poland
    • Posts 122
    • Points 1,655
    Case 149 and 150% ?
    Zb.
  • Thu, Dec 21 2017 2:42 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    Has Avid acknowledged this as a defect? If not, it won't get fixed, right?
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sat, Dec 23 2017 3:11 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    Yes.
  • Fri, Dec 29 2017 11:23 AM In reply to
    • ZFigas
    • Poland
    • Posts 122
    • Points 1,655
    I hope that my picture will be clear for everybody.
    Either I'm ignorant or this is one of the main tasks for Avid Company in 2018 Year.
    https://www.dropbox.com/s/jke6lzugyf82u6c/Avid%20Composer%20on%204K%20monitor.jpg?dl=0
    Happy New Year.
    Zb.
  • Sat, Dec 30 2017 8:13 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    Disappointed to see the resizing issue not fixed in 8.10. Please Avid, fix this so the composer window works as it did in 8.3!
  • Sat, Dec 30 2017 10:57 PM In reply to
    • ZFigas
    • Poland
    • Posts 122
    • Points 1,655
    Thank you for your support.
    I wait for Avid reaction.
    Happy New Year.
    Zb.
  • Tue, Jan 23 2018 4:09 PM In reply to
    • rodpaul
    • Posts 103
    • Points 1,390
    I installed the new 2018 MC software hoping to find the composer window resize issue had been fixed. Unfortunately not. Avid - are you aware of this and are you going to address it? Rolling back to 8.9.3 again which works fine.
  • Tue, Jan 23 2018 4:51 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,779
    • Points 48,295
      Moderator: MCA Mac
    You can also try the following: Right-click on the application shortcut (or on the MC application itself) and choose Properties, Select the Compatibility tag. You will see the option to override high DPU scaling. Select that and choose Application. Then try MC. If that doesn't work, try System (enhanced). Note that you may have to log out and log back in to see any change.
    Dave S.
  • Tue, Jan 23 2018 5:48 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,777
    • Points 62,185
    rodpaul:
    You stated that Avid was aware of this earlier in this thread. if this is not the case hoprfully a mod will escalate this.
    Steve
