Basically I don't see the waveform anymore after I render for example the Maxim audio effect (and NugenLM Correct 2 also), using the AMA Link method. Tried to create another project/user. No success. On file import, everything works. Is there an option to enable?
Thank you!
Later edit.
Tried on 2 MAC PRO machines with the same specs/configs and on one Windows 10 machine (asus rog)
I've often found AMA sources won't display waveforms. ot sure if its the type of file and how the Audio is handled.
A transcode of just the audio normally works.
this is the first time when it happens. AND after upgrading (clean install) to the latest version.
tried with 8.9.1
with this version I can see the waveform when AMA Linking - applying an audio effect+render.
so it's an issue with 8.9.2
8.9.3 also.
Prores 422 on timeline.
apply Gain Effect - render - no waveform
apply Maxim effect - render - no waveform
Tried on 3 machines - Mac/Windows10
no one getting this issue?
Does this happen with other media types ?
I just tried Maxim (AudioSuite clip effect) on XAVC-L material without issue.
Steve
______________________
www.nelliedogstudios.com
From the image you posted waveforms are not enabled.
For better help you should update your specs.
Desktop
Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
Laptop
MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
NLE
DR Studio 18.5|MC 2023.3
3 Heads Digital Films
Waveforms can be enabled from the timeline fast menu as well as the track control panel.
Having the same problem. Lately, been forced to consolidate/transcode, import or create an audio mixdown.
I'm running 8.9.3 on Mac 10.12.6 working primarily with Red footage. Would love for this to get fixed!
Curious about the 8.10 release...
