Latest post Mon, Oct 23 2017 3:28 AM by brett. 3 replies.
  • Wed, Oct 18 2017 7:05 PM
    • Luty
    • Joined on Wed, Oct 18 2017
    • Posts 1
    • Points 25
    Change aspect ratio of media
    Hi all,
    I tried to search a lot but found no topics around the problem I have. I shot 1920x1080p footage at 25 fps but I want my film to be 4:3 so 1440x1080 to keep the best quality. However from what it seems and from what I found Media composer doesn't allow for such dimension. Even if it doesn't what would be the easiest workflow to edit my footage in a way that I get an idea what it looks like in 4:3 and I can actually choose what I want to show in the frame (using frame flex i suppose) and then to export it in 1440x1080p? Thanks.
  • Wed, Oct 18 2017 7:34 PM In reply to
    Re: Change aspect ratio of media
    I would apprach it this way.
    Work in a 1920x1080 project.  Create a 4:3 mask to put on a layer above all your footage in the timeline. As you cut your footage into lower tracks and edit, then add a resize and adjust framing or positioning underneath the mask.
    Finsih your edit.
    Just before export, remove the mask off the upper layer. On the export dialog box, set your Width and Height to 1440x1080, then click the "Crop/Pad" button next to it. On export it will crop off the sides where the mask was hiding the edges and give you the final file you want.
    Follow me at www.twitter.com/redarrowryan [view my complete system specs]
  • Sat, Oct 21 2017 6:43 PM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 701
    • Points 8,020
    in mc recent updates, you can work with mask margin fonction, and have the choice on export to have it on or off.
    symphony 2020.12 - win 10 pro64 v.21H2 - nVidia gtx1080 OC (472.47 studio) - intel i7 6800k @4.2ghz water cooled by corsair H100i V2 - MSI X99A - 112GB... [view my complete system specs]
  • Mon, Oct 23 2017 3:28 AM In reply to
    • brett
    • Joined on Wed, Nov 17 2010
    • tampa
    • Posts 60
    • Points 775
    go to export setting... you can custom export whatever you want your dimensions to be.
    i shoot in 4k and want the widest possible...so i export 3840x1550 crop to pad..now i have a real wide screen look with no black bars
    tinker with those settings for the desired look.
    7820x 32GB ramGTX 1070m.2 a7sII Magic bullet looks > resolve. yep [view my complete system specs]
