Latest post Fri, Apr 3 2020 10:36 AM by pierreh. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Oct 6 2017 12:21 AM
    • raucsavage
    • Joined on Fri, Oct 6 2017
    • Posts 2
    • Points 40
    New problem with Script Sync 2.0
    I've been using Script Sync 2.0 on a big reality TV show for 4 months now with no issues. I've managed to successfully sync over 20 transcriptions, some over 2.5 hours long. But now all of a sudden when I try to sync my latest two transcriptions it will freeze during the syncing process at the very last second. I'm not able to abort, and I have to force quit avid. I've tried starting a new project, changing the sync settings nothing has worked so far.
    Has anyone else had this issue or know of a fix? Is there a cache that I need to clear out and is the indexing data stored somewhere? Maybe that folder is full, but I'm not sure where it would be located.
    I'm using MC 8.8.5 on a mac mini (OSX 10.10.5) (we only use this machine for script sync and then use our other macs for editing.)
    Any help would be great, thank you.
  • Fri, Oct 6 2017 1:20 AM In reply to
    Re: New problem with Script Sync 2.0
    raucsavage I have moved your post from the MC | First forum to the MC Mac Forum so it will be more visible to people using similar setups.
  • Fri, Oct 6 2017 3:18 PM In reply to
    • Posts 11,311
    • Points 232,440
    raucsavage
    Let me take a look at this and see if we can reproduce it
  • Thu, Feb 22 2018 5:47 PM In reply to
    • yowoody
    • Joined on Mon, May 2 2011
    • Posts 2
    • Points 20
    I am having thesame problem, but only with certain scripts. Have yiu come up with any solutions?
  • Fri, Feb 23 2018 5:43 PM In reply to
    • Posts 11,311
    • Points 232,440
    Have you guys tried......   deleting the file called _SearchDB_  ?   This file is the database of the indexed bins within your project.
    If you have ScriptSync activated, you will also see a folder called PhoneticData which contains a number of files with a .pat extension; these files contain the phonetic information for each of the audio clips within your project.  One .pat file will be created per clip.
    I dont think this is the issue ( .pat file ) but it might be worth deleting the SearchDB and then restarting and rebuild it.
  • Fri, Mar 30 2018 6:25 PM In reply to
    • Aren Hansen
    • Joined on Tue, Mar 15 2016
    • Toronto
    • Posts 72
    • Points 780
    I don't see these .pat files or the PhoneticData on my mac. Are they saved with the project?
    MC 2020.8 // OS10.15.6 // iMac 2019 3.6 i9 // 72GB Ram // Vega 48 // [view my complete system specs]
  • Fri, Mar 30 2018 6:32 PM In reply to
    • Posts 11,311
    • Points 232,440
    Aren
    Listed below are the Q/A that shoud help.
    Q:There are folders and files in my Project folder I didn’t create. What are they and what do they do?
    A: In each Project folder, you will see a folder called SearchData which contains a file called _SearchDB_. This file is the database of the indexed bins within your project. If you have ScriptSync activated, you will also see a folder called PhoneticData which contains a number of files with a .pat extension; these files contain the phonetic information for each of the audio clips within your project. One .pat file will be created per clip.
    Q: Is there a file count limit to the PhoneticData folder?
    A: Yes, the PhoneticData folder works like the AvidMediaFiles folder; once the first folder reaches 5,000, it will create another folder with a 2 appended to the name and continue to create new folders as the previous folder gets full.
    Q: Do ScriptSync and PhraseFind share the same .pat files?
    A: No, they are different files, but the files are small enough that this will not adversely affect either performance or storage requirements for most projects.
    Q: How do I activate my ScriptSync license?
    A: ScriptSync 2.0 uses the Avid Application Manager to manage activations and deactivations of its license. For more information on using Application Manager, please refer to the Media Composer Installation Guide
  • Tue, Mar 31 2020 6:48 PM In reply to
    Hello! Ran into this problem with a client yesterday, and as it turned out it was because they hadn't added line breaks to each line of the .txt document.  They used Google docs to create the .txt document and it doesn't give you the option.  So I think AVID was treating each paragraph as a single line of text and trying to figure out how to add script marks for an entire paragraph.  He was using MC 2018.12.10 I believe, so it was pretty up-to-date.
    So basically re-formatted his script for him and included line breaks in the each line of text (which is basically a carriage return for each line - .txt documents treat lines differently than say a Google doc).  Anyway solved his issue where it got stuck on indexing by formatting the scripts properly with line-breaks.
  • Fri, Apr 3 2020 10:36 AM In reply to
    • pierreh
    • Paris, London
    • Posts 1,269
    • Points 15,355
    Yep that's still one of the weakness of ScriptSync. v1 forced you to cut the paragraph so it was annoying to display on a different monitor setup than the one used for creating the scripts. v2 introduced soft-wrapping but it was never made clear that the indexing is still done on a line basis. I was on a show like that, and each reply from the interviewees was a whole paragraph. ScriptSync was still a life saver, but it was far less precise than it can be - especially when the answers were long.
    - Work: MacPro 2010 3.46Ghz 12 Cores 48Gig RAM, Mojo DX, 10.14.6 - Home: MacBookPro 2.5Ghz quad-i7, 16Gig Mem and SSD OSX 10.11.6 [view my complete system specs]
