I decided to start linking and transcoding only what I needed in the project rather than importing. In a 1080 project with 1080 material I find I can not scrub across as well. I can use J,K,L but I want to go faster. Question: is there any way to reduce the quality in order to scrub? I have no options to go to proxy in the settings. You can see my computer specs in my profile as it's up to date.
MC 8.4.5 Built Workstation-Windows® 7 Professional, 64bit,/ Intel® CoreTM i7-4770K processor/ NVIDIA Quadro K2000D 2GB/16GB Dual Channel DDR3 SDRAM at 1600MHz /MSI Z87-G45 Mother Board/650 Watt Power/ Super Multi Blue Writer (LG BH12LS38)/ AVID C-400 for audio interface Pro Tools MP
The fastest the PC (SSD, CPU, Memory, Media Cache settings) the fastest the scrub, edit, export etc.
This is even more true for AMA clips.
Desktop
Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
Laptop
MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
NLE
DR Studio 18.5|MC 2023.3
3 Heads Digital Films
I think I can put the source files on an SSD drive and transcode to a hard drive,
I have a 4770K quad I7 core what CPU would be better?
I notice you didn't mention updating the graphics card and it's ram. What would be a good minimum set up to scrub 4K video?
If you want to scrub the same way by AMA as you do with transcoded files,
I would say don't waste your money. It's not going to happen.
I personally always transcode and for my habbit to always backup my projects to another
disk as I work on RAID 0.
P.S. My best bet are on the SSD and CPU. And I think that 16G is not much for this task also.
As I work on multiple projects, I thought if I worked in AMA and just made sub-clips of what I wanted in the project it would keep the project size down and maybe I could archive the entire work project. Thanks for the ideas, I will try to update my computer more.
You are welcome.
George Angeludis: If you want to scrub the same way by AMA as you do with transcoded files, I would say don't waste your money. It's not going to happen.
Agree with George.
Ronald, why don't you transcode all your 4K clips to a low resolution proxy ?
DNxHR LB with reduced spatial resolution/raster dimensions (e.g. "Source 1/4") would create lightweight clips that play/scrub/edit very smoothly.
When your rough selection is done, you can relink then transcode to your desired final (full frame size / hi res) format for fine editing.
It depends on the format of the linked files XDCAM - no problem, Long GOP panasonic files - not so good.
I installed an NVME SSD and put the files on there, along with an overclocked i7 7820 8 core its not bad at all. Even the panasonic files are usable (with the CPU maxed out) I have got 9 streams of HD multicam running OK with linked files.
