Latest post Tue, Dec 12 2017 8:31 AM by JonnyL. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Aug 24 2017 11:14 AM
    • Simon_h
    • Joined on Mon, Jun 20 2011
    • Cambridge, UK
    • Posts 85
    • Points 1,080
    After changing audio level timeline won't play.
    Has anyone come across this?
    Every so often, I change the audio level using the audio mixer and press Space - nothing.  The only way I know to fix it is to exit Avid and restart.  Anyone know how to fix this?
    AVID 2019.12 on HP Z820 MT XEON, 2GhZ, 32GB, Windows 10, Nvidia Quadro 2000, Crucial SSD Hard Drive with several WD Blacks for media. TMPGEnc 7 for encoding... [view my complete system specs]
    New Template
  • Thu, Aug 24 2017 1:28 PM In reply to
    Re: After changing audio level timeline won't play.
    A "bad" plugin maybe?
    Desktop PC
    Corsair RM750X|Asus P8Z68 Deluxe(Gen3)|i7 2600K@4.4|Corsair 32G DDR3|PNY Quadro P2000(442.92)|Samsung 850 Pro SSD(OS) 256 GB|2x1TB Crucial MX500@RAID 0|2x500GB Mushkin SSD@RAID 0|LG BH16NS40|W10 Pro 64bit|Media Composer Software 2020.6 with Symphony Option on Dongle|2xHP 22'' Monitors|M-Audio AV30 Speakers.
    3 Heads Digital Films
    • Posts 11,311
    • Points 232,440
    Before I delve into this Simon....
    Are your specification listed correct?   MC version?  OS?
  • Thu, Aug 24 2017 9:09 PM In reply to
    • Simon_h
    • Cambridge, UK
    • Posts 85
    • Points 1,080
    Yes I've just double checked and added some info about the kind of media I'm using.  I appreciate your attention to this issue.
    New Template
  • Thu, Aug 24 2017 9:12 PM In reply to
    • Simon_h
    • Cambridge, UK
    • Posts 85
    • Points 1,080
    Thanks for the suggestion George.
    In this case, there were no plug-ins in use on the audio, as probably the other times it happened, as its generally early on in my workflow.
    New Template
  • Sat, Aug 26 2017 8:44 PM In reply to
    • Random Post
    • Toronto, canada
    • Posts 81
    • Points 1,025
    Yep.  Happens to me as well.  Usually after adjusting an audio level (on mixer) on either the source or the record side.  My work around is to hit the play icon on the source (or record) that was just adjusted.
    Often after adjusting the audio level, I'll hit the "L" key and nothing happens.... I'll hit the "L" key again and nothing.  If I click (with mouse) on the play icon, it starts to play at high speed.... ie: if I did hit the "L" key twice, it will play at 3 times regular speed (twice for the "L" and once for the play icon.)
    It's odd, but I never have to quit Avid.... everything settles after hitting the play icon.  This seems to happen only on the first time any audio is adjusted.  Hardly ever happens after that.
    MC 8.8.6 on a Z820 Win7/64 48Gb RAM, Black Magic design Decklink Studio 4k... C drive is a Crucial SSD, Internal 6Tb esata (striped 2x3Tb), HP Thunderbolt2... [view my complete system specs]
  • Sun, Aug 27 2017 10:55 AM In reply to
    • Simon_h
    • Cambridge, UK
    • Posts 85
    • Points 1,080
    Interesting findings :)     I think I tried clicking on the play button on the monitor, but not necessarily on the one I adjusted so I might try that as a shortcut until Marianna comes back with some findings.
    New Template
  • Fri, Dec 8 2017 2:54 PM In reply to
    • SaulB
    • Joined on Fri, Dec 8 2017
    • Posts 7
    • Points 95
    This has just happened to me. MC 8.6.5 on a z420 with mojo DX. Made an audio adjustment in mixer and suddenly could no longer play.
    Strangely any keyboad command seemed to stop working, could only, e.g., mark in and out via active command palette ... but even with that I couldn't play. Using command palette I tried loading the source and playing it as per other poster, but no luck.
    Restarting sfotware fixed it.
  • Tue, Dec 12 2017 8:31 AM In reply to
    • JonnyL
    • UK
    • Posts 182
    • Points 2,420
    I am getting this as well.
    Often on new sequences on first audio adjustment the fader is adjusted but there is no adjustment in level.  My solution is to unload the sequence from the record monitor and reload.
    Was there any solution?
    Asus X299, i7 7820, Nvidia 2000M 32GB ram, NVME SSD 8.9.1 ( yes its very fast!) [view my complete system specs]
