Latest post Fri, Jul 14 2017 11:21 AM by stefanocps. 16 replies.
  • Tue, Jul 11 2017 2:49 PM
    basic color correction
    Hello i am arrived at the part cof correcting my video
    I would like to have some hint
    when i enbter the color correction mode and apply some value avid create a track long all the timeline..so i need to cut it everytime according to the clips i am working on it
    is there a way to have avid creating the track only for the clip i am working at?
    i am using the y waveform and i see that the changement in it are applied only when i leave a control bar ...while i am moving it the waveform will not reflect that movement..is that normal?
    last..is there a way to set to default vaue a parameter i am worling at?
    thanks all
    CPU I7 2600k 3.4ghz Ram 32gb Ssd 256gb GPU Nvidia GTX760 Win 10 Avid First [view my complete system specs]
  • Tue, Jul 11 2017 2:51 PM In reply to
    Re: basic color correction
    one more thin
    i notice that the monitor that should show the "NEXT" clip..is showing the nex only when i am at the first clip.
    after that it show a clip that is somewhere in the middle..and will not change it
  • Tue, Jul 11 2017 3:01 PM In reply to
    ok i see if i cut the grey track in corrispondance of each clip then when enetering color correction i ll have a track created just for that portion (see the red dot in the image) , allo the NEXT clip works correctly now
    but now..do i have to make the cut all the timeline long manually?
  • Wed, Jul 12 2017 9:18 AM In reply to
    stefanocps:
    If you want the color correction to apply only to the clip you are color correcting, only turn on the video track with the clip on it. If you must have the color correction on a higher track, then you're going to have to add edits to the higher track.
    stefanocps:
    It's working that way because you have only the highest track turned on, and there are no more clips on that track.
    stefanocps:
    If you want your color correction to be on the top track, then you'll have to add edits like you are doing. If you only turned on the video track for the clip you are color correcting, both of these problems would be solved.
    stefanocps:
    Default parameter for what?
    Media Composer 2020.9 w/Symphony/SS/PF options, HP Z-Book G6 17", i7-9850H 2.60GHz, 32gb RAM, NVIDIA Quadro RTX 3000, Windows 10 Pro [view my complete system specs]
  • Wed, Jul 12 2017 12:58 PM In reply to
    sometimes after adjusting some parameters  i want to revert them to default value
    paramenter like those for highlight, black and shadow and so on
    also i ask again
    the waveform don't respond to change while i am moving the slider (again for changing paramenters like black highlight, shadow..)..but it will show the change only when i stop moving the slider
    is that normal?
  • Wed, Jul 12 2017 1:37 PM In reply to
    stefanocps:
    is that normal?
    Sorry, I missed that. Yes, that's normal.
    stefanocps:
    Not that I'm aware of. (I don't have a Symphony option machine to test with to see if Symphony is different.)
  • Wed, Jul 12 2017 2:55 PM In reply to
    ok i was thinkink to somehting like in premiere where a double click on the fx parameter will set it back to default
    back to the cc, you think is not of use create an higher track for cc?
    now with the same set i have in the pic posted above , with the higher track highlghted only if i try to cc i get an error
    "only cc effect correction can be applied to filler"
    why?
    seem i am doing the same thing  was doing yesterday with no problem..
  • Wed, Jul 12 2017 3:18 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,444
    • Points 17,815
    stefanocps:
    If I'm understanding you correctly -- just remove the effect, then start correcting again.
  • Wed, Jul 12 2017 3:30 PM In reply to
    not a solution thoigh
    sometimes i have worked let s say gain..ok, then gamma, then go to setup...i only want t bring the stuo to start point..i know that it is 0
    but not all the parameter i knpw their defaul value
    deleting the fx will wipe all not only the setup correction
  • Wed, Jul 12 2017 9:08 PM In reply to
    • Ken Lent
    • Joined on Tue, Dec 18 2007
    • California
    • Posts 129
    • Points 1,375
    stefanocps:
    why?
    In the upper left corner of Symphony's Color Correction window, there is a drop-down menu with choices such as Src Segment, Src Clip Name, Master Clip, . . . , and, at the bottom of that menu, CC Effect. All of these choices except for CC Effect are relational options that will apply your correction to multiple clips at once. Because you are applying your correction to a track but not directly to a clip, the relational choices are not applicable. Select CC Effect, and you should be okay.
    On the other hand, you may want to consider applying a relational correction directly to a clip instead, because relational correction is a big part of the power of Symphony.
    Core i7 930 PC 2.8GHz / 18GB RAM / Win10 Pro 64bit / nVidia Quadro K2200 (driver 411.95) / MC 2018.12.9 (Symphony/PF/SS) / BCC AVX 10.0.2 / NewBlue Titler... [view my complete system specs]
  • Thu, Jul 13 2017 2:11 PM In reply to
    something is not clear to me
    now i am applying the cc at clip directly
    i have the track i want to work at highlighetd
    some clips i can apply cc, all of a sudden a certain clip give me the error
    can t really understand why...i have done just the same to the 2 previous clip (both on different tracks though)
  • Thu, Jul 13 2017 2:13 PM In reply to
    ok i see
    what happen is that i have multiple track highlighted
    it is ok untile some clips overlap on to other..then i get error
    in this case i need to highlight only the track i work at
    is a bit complicated like this..isnt 'it?
    am i doing something wrong?
  • Thu, Jul 13 2017 2:38 PM In reply to
    • conleec
    • Los Angeles
    • Posts 1,320
    • Points 17,095
    I know you're trying to use the tools you have available, and nobody probably wants to spend more money if they don't have to, but I just purchased Baselight Edition, and it's pretty fantastic for color correcting within the timeline. Of particular note: it will automatically create edits at each event for you (when you put the correction on an upper layer), and even more importantly, the scopes properly adjust as you're moving the sliders. It's nearly impossible, I find, to use Avid's built-in tools, because the scopes don't change until you've released the controls (as you've discovered).
    Chris
    MacPro 3.33Ghz 12 Core (Westmere, MacPro 5,1), 48Gb RAM, nVidia GeForce GTX 680, Intensity Pro (Desktop Video 10.4.3), OS X 10.13.6, MC 2018.12 [view my complete system specs]
  • Thu, Jul 13 2017 2:54 PM In reply to
    conleec:
    Chris
    i agree the edits that create automatically are really useful
    but the most useful is that the scopes don t change until you release..that is really bad
    it is a pity as apart of this seems quite powerfull tool
    what is baselight edition, another software for cc?
    is it a "plugin" that works still within media composer?
  • Fri, Jul 14 2017 5:21 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,737
    • Points 67,310
    smrpix:
    stefanocps:
    Not in front of a system to double check, but ALT-click should reset a parameter to the default.
    Symphony 20.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
