Latest post Tue, Apr 18 2017 6:21 PM by Tentaor. 4 replies.
  • Sun, Apr 16 2017 9:25 AM
    • Tentaor
    • Joined on Thu, Nov 15 2007
    • Posts 27
    • Points 330
    AMA linked mp3 clicking
    Hi. I edit a sequence with a lot of AMA linked mp3
    When I play the sequence audio has clicking, gaps and others audio failures. Importing the same audo files works properly.
    Why I´ve this problem? It´s a bug?
    How I fix it?
    I trying to import the mp3 and relink the sequence to them but does not work.
    Thanks a lot and sorry for my poor english.
    MAC PRO EARLY 2008 32 GB RAM OSX EL CAPITAN 10.11.6 media composer 8.4.5 [view my complete system specs]
  • Tue, Apr 18 2017 12:02 AM In reply to
    Re: AMA linked mp3 clicking
    Not a bug. MP3's are highly compressd, and typically 44.1kHz.  Video work needs the audio to be 48kHz...so Importing converts the files to that format.  AMA linking audio is never adviced...always import.
  • Tue, Apr 18 2017 9:36 AM In reply to
    • Tentaor
    • Posts 27
    • Points 330
    I can understand it in realtime play of a AMA sequence but i can not undeestand after consolidating the AMA audio. This is a bug clearly.
  • Tue, Apr 18 2017 5:46 PM In reply to
    If you CONSOLIDATE, you are merely moving, not converting. So the audio is still MP3 and still 44.1 or whatever. If you TRANSCODE or IMPORT, then you convert it to a format that Avid works with. Not a bug...you just have to do things properly.
  • Tue, Apr 18 2017 6:21 PM In reply to
    • Tentaor
    • Posts 27
    • Points 330
    CONSOLIDATING or TRASCODING i have the same bug. Audio have gaps and clicks.
    If I import it I have no fails.
    In the times of extracting the tracks of a standard audio CD (44.1Khz) i have never an error loke this if I had checked "Convert Sample Rate when playing" in the Audio Project Settings
    Thanks for your answers!
