Latest post Tue, Mar 7 2017 10:26 AM by usatraveler. 3 replies.
  • Mon, Mar 6 2017 2:13 PM
    • WAIF2318
    • Joined on Tue, Nov 15 2011
    • Posts 336
    • Points 4,175
    a importing problem
    can AMC import 1920x1080i m2t files? thanks to any reply in advance.
  • Mon, Mar 6 2017 8:26 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,779
    • Points 48,295
      Moderator: MCA Mac
    Re: a importing problem
    MC can import HDV files (1440x1080). I don't know about 1920x1080. Bear in mind that HDV are non-square pixels and display properly at 1920x1080. Do you know what camera created the files? Or are these exports from another application?
    Dave S.
  • Tue, Mar 7 2017 7:44 AM In reply to
    • WAIF2318
    • Posts 336
    • Points 4,175
    dear DStone,I don't known the files what camera created,to be sure is MC8.45 canon support the format.
  • Tue, Mar 7 2017 10:26 AM In reply to
    If the MTS if HDV - then this is one of the VERY rare formats where "import" is the better way to go, and linking doesn't work.
    But if it's AVCHD, you link them.  And - don't link to the file itself, you should link to the root of the folder structure.  There should be a folder called "PRIVATE" - don't link to it, go one level higher than that, and link.
    Your clips will appear in your bin.  You'll probably have to transcode for smooth performance.
    (SYSTEM 1) iMac Late 2012 27" (13,2), Mac OS X 10.15.5, Avid Media Composer 2020.6 w/Symphony, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX... [view my complete system specs]
