Latest post Fri, Mar 3 2017 4:02 PM by Marianna. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Feb 13 2017 5:13 PM
    AvidBinIndexer crashing on Quitting.
    every time i quit th MC the AvidBinIndexer crashes,  i updatet to the last version, still happening.
    what can i do???
    Process:         AvidBinIndexer [11280]
    Path:            /Applications/Avid Media Composer/AvidMediaComposer.app/Contents/MacOS/AvidBinIndexer.app/Contents/MacOS/AvidBinIndexer
    Identifier:      com.avid.AvidBinIndexer
    Version:         1.0 (1)
    Code Type:       X86-64 (Native)
    Parent Process:  launchd [261]
    Responsible:     AvidBinIndexer [11280]
    User ID:         502
    Date/Time:       2017-02-13 18:06:38.559 +0100
    OS Version:      Mac OS X 10.9.5 (13F1911)
    Report Version:  11
    Anonymous UUID:  17E13D20-7BDD-F7DD-AE36-161AB92F3719
    Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000125c06cd3
    VM Regions Near 0x125c06cd3:
        mapped file            0000000125b25000-0000000125b9d000 [  480K] rw-/rwx SM=COW  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/Resources/English.lproj/Localized.rsrc
    MORE IN THE ATTACHMENT
    3 GHz 8 core Intel Xeon E5 MacProlate 2013/ 64 GB / 10.13.6 / MC18.12.3 / AMD FirePro D300 2048 MB [view my complete system specs]
  • Mon, Feb 13 2017 5:22 PM In reply to
    • Posts 10,991
    • Points 228,305
    Re: AvidBinIndexer crashing on Quitting.
    Hey there
    In the projects folder, there is a "SearchData" folder.   It contains a file called "_SearchDB_".
    When this file gets corrupt it can cause the Bin Indexer to stop functioning correctly.
    Delete it and Avid will rebuild the file when you open the project.
    Try that and report back
  • Tue, Feb 14 2017 11:22 AM In reply to
    thank you for your very quick reply!
    no:  deleting _SearchDB_ does do the trick.  after quitting MC it still chrashes, see reports att.
    i just realized, when opening the MC the TranscodeServiceWorker and QuicktimeOPserver dont work.
    i can work normally, i just cant quick properly.
    greatings from Ausrtria.
  • Tue, Feb 14 2017 4:15 PM In reply to
    • Posts 10,991
    • Points 228,305
    this was an issue back in 7.0.3 timeframe....  and was related to 10.9.x of the OS.
    I know that a complete unistall and reinstall of MC reoslved it for most and the rest updated their OS as well.
    Are you able to uninstall MC and try that route first?
  • Tue, Feb 14 2017 6:03 PM In reply to
    thanks, ill try to reinstall MC but not untill next week.  i dont like the new OS,  i still miss the 10.8.6!
  • Fri, Mar 3 2017 3:50 PM In reply to
    HI Marianna,
    finally had the chance to uninstall / delete all _SearchDB_ / repair permissions / restart / reinstall / repair permissions.
    i took the new MC 8.8, install and opening projekt worked super!
    on opening the MC  the TranscodeServiceWorker does not responce.
    Call graph:
        2918 Thread_18177   DispatchQueue_1: com.apple.main-thread  (serial)
        + 2918 start  (in libdyld.dylib) + 1  [0x7fff92f055fd]
        +   2918 main  (in TranscodeServiceWorker) + 393  [0x108885e84]
        +     2918 Threads::SemaRepNative::Decrement(char const*, long)  (in AvidCoreThreads) + 209  [0x10933b823]
        +       2918 _dispatch_semaphore_wait_slow  (in libdispatch.dylib) + 147  [0x7fff890ac9be]
        +         2918 semaphore_timedwait_trap  (in libsystem_kernel.dylib) + 10  [0x7fff8f8b8a6e]
        2918 Thread_18178   DispatchQueue_2: com.apple.libdispatch-manager  (serial)
          2918 _dispatch_mgr_thread  (in libdispatch.dylib) + 52  [0x7fff890aa136]
            2918 _dispatch_mgr_invoke  (in libdispatch.dylib) + 239  [0x7fff890aa421]
              2918 kevent64  (in libsystem_kernel.dylib) + 10  [0x7fff8f8bd662]
    editing works fine!
    on quitting the AvidBinIndexer still chashes:
    Date/Time:       2017-03-03 16:45:24.407 +0100
    Report Version:  11
    Exception Codes: KERN_INVALID_ADDRESS at 0x0000000120753cd3
    VM Regions Near 0x120753cd3:
        mapped file            0000000120672000-00000001206ea000 [  480K] rw-/rwx SM=COW  /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/Resources/English.lproj/Localized.rsrc
        MALLOC_LARGE           00000001207c2000-0000000120881000 [  764K] rw-/rwx SM=PRV
    Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
    0   ???                           0x0000000120753cd3 0 + 4839521491
    1   com.apple.CoreFoundation       0x00007fff8c44e6ca +[__NSArrayI __new:::] + 90
    2   com.apple.CoreFoundation       0x00007fff8c44e38e CFArrayCreate + 142
    3   com.apple.CoreFoundation       0x00007fff8c4f63da __CFDateFormatterGetSymbolsArray + 362
    4   com.apple.CoreFoundation       0x00007fff8c4f6109 CFDateFormatterCopyProperty + 1257
    5   org.qt-project.QtCore         0x00000001054615f7 QSystemLocale::query(QSystemLocale::QueryType, QVariant) const + 2807
    6   org.qt-project.QtCore         0x000000010524d1f9 QLocale::dayName(int, QLocale::FormatType) const + 153
    7   org.qt-project.QtCore         0x0000000105228341 QDate::toString(Qt::DateFormat) const + 609
    8   com.avid.searchsupport         0x0000000107486719 MyOutputHandler(QtMsgType, QMessageLogContext const&, QString const&) + 218
    9   org.qt-project.QtCore         0x00000001051d69ed qt_message_output(QtMsgType, QMessageLogContext const&, QString const&) + 13
    10  org.qt-project.QtCore         0x00000001052c9bd0 QDebug::~QDebug() + 96
    11  com.avid.AvidBinIndexer       0x000000010515d57e main + 2267
    12  libdyld.dylib                 0x00007fff92f055fd start + 1
    I can life with that, as long as i can edit fine, its just a hastle, and does not feel good...
    kind regards michael
  • Fri, Mar 3 2017 4:02 PM In reply to
    • Posts 10,991
    • Points 228,305
    Michael
    Can you emailme this thread and also include your system ID. I tried to fnd you via your email on community but it is not tied to anything.
    email is below
