Latest post Wed, Feb 1 2017 6:14 PM by Vadym. 1 replies.
Page 1 of 1 (2 items)
  • Mon, Jan 30 2017 3:42 PM
    • Francesco
    • Joined on Wed, May 16 2012
    • Pisa - Italy
    • Posts 69
    • Points 680
    AMT growing clips
    HI
    I am facing the problem to generate an AMT clip and access it from Media composer while
     creating (growing AMT clip).  There is a way to do this ?  Moreover if for any reason there is a power fail and
    clip creation is interrupted, there is a way to recover ? That is to continue recording clip without restarting from
    first frame ?
    I saw that AMT SDK creates files inside the subdirectory "Creating" but the ".aaf" file is created at end of creation
    (perhaps when closing file).  There is the availability to force creation of ".aaf" file while recording ?
    Regards
    Filed under: ,
  • Wed, Feb 1 2017 6:14 PM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 236
    • Points 2,825
    • Avid Developer Moderator
      Avid Employee
    Re: AMT growing clips
    You can start writing a new clip from the point of fail if you keep tracking where fail occurs. Media append is not supported.
    The AMT call that creates media in the Creating folder is designed to create a full clip before it can be used. AAF is generated at the clip closing time. This is by design.
    You can use CreateAmtInterplayClip call for creating in-progress clips. Please refer to the AMT documentation for details.
