Latest post Thu, Jul 2 2020 3:02 AM by Telegram!. 33 replies.
Page 3 of 3 (34 items) < Previous 1 2 3
  • Tue, Jun 30 2020 3:42 PM In reply to
    • SaulB
    • Joined on Fri, Dec 8 2017
    • Posts 4
    • Points 60
    Re: FrameFlex in multicam mode
    Telegram!:
    With your 90 degree-off footage, are you aware you can or have you tried Transcoding the (presumably MP4) with the FrameFlex coorection baked-in?
    That might work in some circumstances, but unfortunately the facility's workflow is to convert everything to DNxHR LB at native frame rate and frame size and then conform for online/grade.
    Telegram!:
    Just curious, how many individual camera sources are used in your GroupClips?
    Varies from 3-5 on this episode.
  • Tue, Jun 30 2020 3:45 PM In reply to
    • SaulB
    • Posts 4
    • Points 60
    Telegram!:
    Rotate at any angle is not propigating into a Group Clip used in a Sequence. A simple Zoom-In did work
    You're right, same for me on 2018.12.10 ... I was only concerned with clips that were on their side so didn't test a straightforward resize. That would explain why the on their side clips are oddly cropped as well ... the resize info has carried through, but not the rotate.
  • Wed, Jul 1 2020 11:56 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,743
    • Points 61,875
    Is this also the case with MC 2020.6?
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Jul 2 2020 3:02 AM In reply to
    SaulB:
    unfortunately
    Agreed.
    Multicam/Group Clips with save-able-to-bin, per-camera angle, per-Timeline clip, "3D warp-style" effects. That's the ticket.
