Latest post Thu, Jul 2 2020 3:02 AM by Telegram!. 33 replies.
Page 2 of 3 (34 items) < Previous 1 2 3 Next >
  • Tue, Feb 26 2019 12:54 AM In reply to
    Re: FrameFlex in multicam mode
    Sorry you misinterpreted my tone Nick, I did try to make it clear that in fact, I wans't having a go but merely pointing out that this is a feature that would be greatly welcomed and that workarounds suck, much as you had done earlier in the thread.  I'm sorry you took that personally. Please don't compare what I said to someone making racist comments, I'm not interested in having that associated with posts I make on this forum, I think that was unnecessary.
    Andi
    HP ZBook G5 15 2.6Ghz 6-core i7 Nvidia Quadro P2000 4GB 32GB RAM Win 10 Pro MC Ultimate 2018.12.8 MacbookPro 15 2019 6 core 2.6GHz i9 32GB RAM... [view my complete system specs]
  • Tue, Feb 26 2019 5:07 AM In reply to
    Stinks that Frame Flex doesn't work in multicam mode.  This will only become more of an issue as we cut 6K, 8K, "whatever K" footage moving forward.  Avid needs a way to access frame flex within a multi cam sequence. A way to open the multi cam group like a nested layer and access the frame flex within? Does that ability exist in 2018.12?   (I don't remember hearing anything about that in the much-lauded multicam update hoopla last month.)
    Avid Media Composer 2018.12 Intel i9 9900K desktop Windows 10 Pro 64GB RAM BlackMagic Design Decklink Mini Monitor Nvidia RTX2080 display card [view my complete system specs]
    Jason Spencer, Director/DP/Editor digitallunchbox.com
  • Tue, Feb 26 2019 6:52 AM In reply to
    wjasonspencer:
    There are so many variations of requests, so many potential needed workflows— it’s staggering. I think it’s helpful (like in the above post) to simply ask for what each of us wants and why, to build forward momentum.
    I think our engineers are always steps ahead in terms of long-range planning, but perhaps now and here would be a good time and place to hear a little from them about their overall vision for future releases, re: Multi-cam, FrameFlex, Crop/Zooms, Pan & Zooms, 3D Warps, Sub-frame Audio slipping & Grouping from Tineline.
    I don’t use any other NLE, but my question is this: is there a product that allows mixed frame-size, mixed frame rate, Pan/Zoom, Crop/Repositioning of Multicam?
  • Tue, Apr 30 2019 6:46 PM In reply to
    • J. Seibel
    • Joined on Wed, Dec 18 2013
    • Los Angeles
    • Posts 29
    • Points 335
      Avid Certified User
    We are having this problem too.  We are on Avid 2018.11.0.  No Frame Flex in Multicam even though individual clips have Frame Flex.  Come on Avid.
  • Sun, May 5 2019 6:41 AM In reply to
  • Fri, May 31 2019 1:12 PM In reply to
    2018.12.3 Same issue.
    Not just annoying to have to commit multicam edits before frameflexing but also not efficient if theres multicam changes to to the cut after the 'commit multi cam edits/frameflexing" happens. Avid please address. Thank You.
    - jared
    MC Version 2020.4 | Windows 10 64 bit | 128 GB DDR4 Ram | ASUS X299-A | Processor: Intel(R) Core(TM) i9-7900X CPU @ 3.30GHz, 3301 Mhz, 10 Core(s), 20 Logical... [view my complete system specs]
  • Wed, Jul 10 2019 2:07 PM In reply to
    • Marty
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 942
    • Points 11,020
    2018.12.5 same issue - no frame flex with group clips and once I match frame to the group clip, also the subclip has no frame flex information anymore.
    all different setups in various editing suites. my own: MC 2018.2, OSX 10.12.6, iMac (Retina 5K, 27-inch, 2017), 4,2 GHz Intel Core i7, 40GB RAM, Radeon... [view my complete system specs]
    www.film-editing.de
  • Thu, Aug 22 2019 9:51 AM In reply to
    Just to give this one a nudge.
    Also have the same issue, frameflex not working in multicam mode.
    The last version of MC where it worked was 2018.2
    Commit multicam edits workaround may be acceptable at edit lock, but not before.
    Does anyone have an update please?
    Work: iMac Retina 5K, 27" 2017 3.4Ghz i5, 24GB 2400 MHz DDR4 Memory, 256GB SSD, Radeon Pro 570 4096MB. Shared network storage. Mac OSX 10.12.6 Avid... [view my complete system specs]
  • Fri, Feb 14 2020 6:41 PM In reply to
    • cls105
    • los angeles
    • Posts 509
    • Points 6,550
    This should really be fixed.  Frameflex in multicam is needed badly.
    Thank You
    w10, mc 2020.4, diy x299 7940x [view my complete system specs]
  • Sat, Feb 15 2020 5:35 PM In reply to
  • Tue, Feb 18 2020 2:31 AM In reply to
    • Rob
    • Joined on Thu, Nov 11 2010
    • NYC
    • Posts 118
    • Points 1,510
    Hello Avid engineers. When will we have frameflex with Multicam clips.
    I'm stuck to using resize on clips.
    MC 2019.11 Nitris DX Z820, 64 GIGS, Windows 7 64, SP2 [view my complete system specs]
  • Sun, Jun 28 2020 11:02 AM In reply to
    • SaulB
    • Joined on Fri, Dec 8 2017
    • Posts 4
    • Points 60
    Telegram!:
    Having this problem still in 2018.12.10 (working on a facility system so can't try the latest version), to add to all the 4K/8K/etc issues, a more down to Earth problem I am facing is cutting a lot of covid-lockdown-smartphone-shot angles where clips end up on their side and need a 90 degree rotate in frameflex. Doesn't work in MultiCam of course.
    Telegram!:
    Pretty sure you can do all this in FCPX, plus the ability to adjust multiclips once created, and apply whatever effect you like to an angle (even have a composite as an angle). For all its faults, FCPX's multicam functionality is exceptional (IMO).
  • Sun, Jun 28 2020 1:43 PM In reply to
    With your 90 degree-off footage, are you aware you can or have you tried Transcoding the (presumably MP4) with the FrameFlex coorection baked-in?
    Just curious, how many individual camera sources are used in your GroupClips?
  • Tue, Jun 30 2020 12:53 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,741
    • Points 61,845
    Anyone else try this with 2020.6? I did a brief test that suggested FrameFlex carried through to the multi-cam edit...
    Steve
    ______________________
    www.nelliedogstudios.com
  • Tue, Jun 30 2020 1:48 PM In reply to
    .Just tried it again: on v2018.12, Rotate at any angle is not propagating into a Group Clip used in a Sequence. A simple Zoom-In did work. The OP is correct, I would say. this was on transcoded Media, and also on Linked clips used in the Group.
    Also tried making a new Group Clip incorporating a camera master clip (linked) that was Rotated. Only the zoom transferred to a new GroupClip or to a new Sequence using it. But not the Rotate.
    So, it seems that for use in Groups, if Rotate is needed at early stages of editing, a pre-Transcode to a FF-baked, Rotated Clip, possibly at a higher Resolution, would be needed for normal multicam editing.
