Latest post Tue, Nov 1 2016 2:59 AM by Mondo. 1 replies.
Page 1 of 1 (2 items)
  • Sun, Oct 30 2016 10:44 AM
    • WAIF2318
    • Joined on Tue, Nov 15 2011
    • Posts 340
    • Points 4,205
    Sony XAVC_XDCAM(Folder)ama disappeared in MC8.5.3 for help
    I originally used ama PDZK-MA2V3.4.0  in MC8.4.5,recently upgraded to MC8.5.3 and ama PDZK-MA2V3.5.1 but cannon find
    Sony XAVC_XDCAM(Folder) only Sony XAVC_XDCAM(*.mxf),my camcoder is sony pxw-z150,can anyone help me?thanks in advance.
  • Tue, Nov 1 2016 2:59 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,635
    Re: Sony XAVC_XDCAM(Folder)ama disappeared in MC8.5.3 for help
    Make sure you manually set Sony XAVC_XDCAM as the plug in in the source browser (don't use automatic). I don't kow what else to tell you as you haven't posted your system specs or mentioned what version of Avid you are using. Please psot your system specs as priority 1.
    John
