Latest post Wed, May 16 2018 1:09 AM by jray. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Aug 17 2016 8:22 PM
    • jray
    • Joined on Tue, Mar 1 2011
    • Posts 65
    • Points 765
    Custom Bin View Changes on Restart
    For my new project I created a custom bin view in MC 8.5.3 and saved it as "Movie". I created custom columns called "Scene#" and "Take#" because the default Scene and Take columns don't work with grouped clips for some reason. Then I arranged my columns like so: Color, Icons, Scene#, Take#, Comments, Camera, Name, etc. The clip names aren't very useful for me, so I pushed them down the line. Once I had it all set up this was saved as bin view "Movie".
    From time to time, and for certain when I restart MC, my custom bin view columns are messed up appearing like this: Color, Icons, Name, Take#, Comments, Camera, Scene#, etc. The bin view shows "Movie". I rearrange them back to the order I want and resave the bin view. This works for a time until I have to do it again. Is there any way to keep my custom view from changing?
    Avid MC 05.2020, MacBook Pro 2019 - 8 Core i9 - Radeon Pro 5500m - 64GB RAM, OS 10.15.4 [view my complete system specs]
  • Wed, Aug 17 2016 8:38 PM In reply to
    Re: Custom Bin View Changes on Restart
    Have you tried simply changing to a different view and then back to "Movie"? You won't lose any data in your custom columns.
  • Wed, Aug 17 2016 8:58 PM In reply to
    • jray
    • Posts 65
    • Points 765
    I hadn't, I was just reselecting my preset which didn't do anything. I restarted and tried your suggestion, it still changed the view by moving "name" to its default position, but at least the rest of my columns remained in order so I can simply slide "name" past them to get back to my preset. An improvement for sure, but I hope Avid will fix the issue.
  • Fri, Sep 2 2016 7:11 PM In reply to
    • jray
    • Posts 65
    • Points 765
    I would really like to get this issue escalated somehow. Every time I restart MC my saved bin view changes. The "Name column" reverts back to its default position in the view after color and cip icon. My saved view is:
    Color, Clip icon, Scene #, Take# (these are custom columns because the built in scene and take columns don't allow you to add data for grouped clips), Comments, Camera, Duration, Tracks, Name.
    When I restart MC it looks like this:
    Color, Clip icon, Name, Scene#, Take#, Comments, Camera, Duration, Tracks
    Once I have restarted I slide the Name column back down to where it belongs and resave the custom setting, however even after I have done this if I reopen a bin that was previously set to my custom view it has also reverted the Name column to its default position. Changing it to a different view and then back again does nothing, and so I'm constantly having to slide the Name column back down to where I want it. This is really frustrating.
  • Mon, May 14 2018 11:12 PM In reply to
    • ematteso
    • Joined on Mon, May 14 2018
    • Posts 10
    • Points 130
    I realize this was a long time ago but did you ever find a solution? I'm experiencing a very similar issue with MC 6.5.
  • Wed, May 16 2018 1:09 AM In reply to
    • jray
    • Posts 65
    • Points 765
    Unfortunately no, after I finished that project I didn’t need that view anymore. I haven’t messed with it since then.
