Latest post Fri, Aug 12 2016 11:39 AM by Pheral. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Aug 11 2016 9:16 AM
    Composer does not like having monitors switched off.
    Is there any way around Media Composer shutting itself down when the monitors are turned off?  It thinks the resolution of the desktops has changed and requests a restart which is not good.  We ingest a lot of media over night and do not want monitors running when no-one is in the building.
    MC/SN 2019,2023.3 x 20 Z4,Z400/420/440/800/820 PC's on W7/10/11 x64. 3 x Mac, 4 x PT 2023.3 HDX, 3 x S6 , X-MON, all on PCs. NEXIS E4 & ISIS 5000... [view my complete system specs]
  • Thu, Aug 11 2016 2:24 PM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 966
    • Points 12,280
    Re: Composer does not like having monitors switched off.
    I'm not seeing this on my systems.  We often transcode material ovenight and just turn off the monitors, then turn them back on in the morning.
    Media Composer v8.9.2 | Windows 10 Professional 64-Bit | Supermicro X10DAi | Intel Xeon E5-2620 v4 Broadwell (x2) | Noctua NH-D9DX i4 (x2) | PNY GeForce... [view my complete system specs]
  • Thu, Aug 11 2016 2:27 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 1,066
    • Points 13,550
    Have you tried going into the OS advanced power options and setting the monitors to go into standby after (say) 30 minutes. I know this works when MC is running and the workstation is left unattended, but I'm not absolutely sure if this would work during a long ingest process.
    Bruno
    HP Z800, HP G9 Fury, SonnetFusion RAID, Mojo DX, Decklink 4K, Ultrastudio 3G/4K, Symphony 2018 & 2023, Boland BVB25 OLED, JVC DTV1910 HD CRT, Eizo... [view my complete system specs]
  • Thu, Aug 11 2016 3:30 PM In reply to
    We are not seeing this either and we have a lot of users doing this on a regular basis.
    As mentioned, check your OS power settings, your EFI/BIOS and drivers. Even check the monitor cable.
    MC 2023.8, W11, ASUS z690m, Intel 13900K, MSI 4090 Suprim Liquid, 128GB RAM, Samsung 980 Pro M2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Ventura... [view my complete system specs]
  • Thu, Aug 11 2016 4:11 PM In reply to
    Digging into this a bit further it is a huge issue for a lot of people.  Just Google it for yourselves.  It seems that if you are using Display Ports which have PNP capabilities that can't be turned off.  So whenever the monitor goes to sleep or is switched off, the computer defaults the resolution to 1024x 768.   However, there is a fix.  I have tried it on my Z440/QuadroK2200 dual monitor port set up and I have rebooted, switched both monitors off and on to have no resolution resize and "please restart" from MC/SN request.   It is to do with the EDID status and you have to load it from a file you save and reload to/from your PC.  The link for the how to is here:-
    https://sites.google.com/site/ebobster/stuff/displayportblanking
    I'll let you know how it goes over the next few days.
  • Thu, Aug 11 2016 5:40 PM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 966
    • Points 12,280
    Yeah, this is apparently a response by the OS to the sudden 'absence' of devices connected to the display ports when you turn off the monitor, and I find references to this behavior going back to 2011.  It's not unique to Nvidia cards, either, as you'll find as many of the same problems from ATI users.  DVI ports don't display the same behavior.
    Not really a Media Composer issue, however.
  • Fri, Aug 12 2016 2:45 AM In reply to
    • Leo153
    • Joined on Sun, Jul 1 2007
    • Lenox, MA
    • Posts 412
    • Points 5,185
    If I shut off the 2nd monitor of a 2 monitor config. while Avid is active, I get an error. If I'm doing an overnight render I launch MC with only the "A" monitor turned on, I can turn that monitor off durring the render/export.
    Leo
    MC 2018.12, BCC 10, Nvidia Quadro K4200,ver.340.84, QT 7.7.4, HP Z840 3.06 12 core, 32 Gig RAM, G-Tech G-Speed eS, 12 TB RAID5, GTech Studio 6TB Thunderbolt... [view my complete system specs]
    Filed under: ,
  • Fri, Aug 12 2016 10:35 AM In reply to
    Pheral:
    Er, yes it is.  It may not be Media Composer's fault, but it is an issue when your ingest stopped and the editor is waiting for their media.
  • Fri, Aug 12 2016 11:39 AM In reply to
    • Pheral
    • Sylva, NC USA
    • Posts 966
    • Points 12,280
    My point was that it's not an issue that Avid is responsible for causing.  I agree that it may be an issue for you, but the answer to the problem is going to lie with some OS or GFX configuration, not in some setting within Media Composer.
