Latest post Tue, Jan 28 2020 4:39 PM by NYnutz. 61 replies.
Page 4 of 5 (62 items) < Previous 1 2 3 4 5 Next >
  • Wed, Dec 4 2019 9:02 AM In reply to
    • Rob253
    • Joined on Fri, Dec 4 2009
    • Amsterdam
    • Posts 13
    • Points 175
    Re: 8.5 and Quicktime_OPServer (not responding) issues
    Hi Erik,
    Normally when Avid runs , you will see a process called "AvidBinIndexer" When you open the console in Avid. ( Tool menu > Console ) and type "DisableSearch" "enter" ( without the ")you will see following message in the console 'Search client support will be disabled on subsequent launches.'
    Close Avid , and relaunch.  The AvidBinIndexer process should now be deactivated.
    Kind regards,
    Rob.
    MacPro 2011 model 3.3GHz quadcore 16GB memory, Apple raid card, Kona3 card, 10Gb/s network OSX 10.7 MacPro 2010 model 2.4GHz 8-core, 20GB memory, Nitris... [view my complete system specs]
  • Wed, Dec 4 2019 11:43 AM In reply to
    • Erik Bäfving
    • Joined on Sun, Nov 13 2011
    • Malmö, Sweden
    • Posts 21
    • Points 230
    Thanks Rob. I tried that but didn´t work. The spinning ball just came up again and I had to force quite and reboot. Loosing some work. This happens like 5-10 times a day.
    MacBook Pro Retina 15" 2,5 GHz Intel Core i7 16 GB 1600 MHz DDR3 NVIDIA GeForce GT 750M 2048 MB Media Composer 8.2.0 [view my complete system specs]
  • Wed, Dec 4 2019 12:09 PM In reply to
    • Rob253
    • Amsterdam
    • Posts 13
    • Points 175
    Hi Erik,
    Any playback hardware connected ?  If so try without. ( physically I mean. The disconnect hardware in avid does not unload the drivers )
  • Wed, Dec 4 2019 1:18 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,601
    • Points 43,355
    This may not have anything to do with your problem, but do you have Fast Scrub enabled?  In the past it has caused beach balls.  I just disable it in all systems.  It may be fixed, but I would not know.
    Jef
    Jef Huey
  • Wed, Dec 4 2019 1:19 PM In reply to
    • Posts 10,935
    • Points 227,490
    Erik
    Did you try and launch QuickTime Player  and go into its Preferences, deselect the "Show Content Guide automatically" and then quit QT.  Launch your Media Composer and is the problem gone?
  • Wed, Dec 4 2019 2:14 PM In reply to
    • Erik Bäfving
    • Malmö, Sweden
    • Posts 21
    • Points 230
    Yes I have it enabled. But I just unchecked it now. We´ll see if anything changes. Thanks for the tip.
    Erik
  • Wed, Dec 4 2019 2:15 PM In reply to
    • Erik Bäfving
    • Malmö, Sweden
    • Posts 21
    • Points 230
    Nope, no playback hardware connected. Thanks for trying to help.
  • Wed, Dec 4 2019 2:18 PM In reply to
    • Erik Bäfving
    • Malmö, Sweden
    • Posts 21
    • Points 230
    Hmm, I can´t seem to find the "preferences" in my Quicktime player. The version of Quicktime I have is 10.5 and there is no "preferences" in the menu at all...
    Erik
  • Fri, Jan 24 2020 5:03 PM In reply to
    • alexdjm
    • Joined on Fri, May 20 2011
    • Posts 19
    • Points 275
    Hi Erik, did you solve this at all - I have the same problem!
    Alex
  • Sat, Jan 25 2020 1:56 AM In reply to
    • Posts 10,935
    • Points 227,490
    Alex and Erik
    What OS are you using?
  • Sat, Jan 25 2020 10:44 AM In reply to
    • alexdjm
    • Posts 19
    • Points 275
    Hi Marianna,
    macOS Sierra 10.12.6
    It was fine until a month or so ago. Now certain sequences either crash straight away or hang.
    Any thoughts?
    Alex
  • Sat, Jan 25 2020 12:14 PM In reply to
    • Erik Bäfving
    • Malmö, Sweden
    • Posts 21
    • Points 230
    My problem is solved. It seemed to be an error with my hard drive.
    cheers
    Erik
  • Sun, Jan 26 2020 6:28 PM In reply to
    • Posts 10,935
    • Points 227,490
    alexdjm:
    Hi Marianna,
    Any thoughts?
    Alex
    Alex
    Can you run the disk utility on your internal drive please?  See if that works and then report back please.
  • Sun, Jan 26 2020 8:59 PM In reply to
    • alexdjm
    • Posts 19
    • Points 275
    Hi
    Do you mean First aid in the Disc Utility? I have run that and no problems identified.
    Has not made any difference to the
    Quicktime_OPServer (not responding) issue though
    Alex
  • Mon, Jan 27 2020 8:48 AM In reply to
    • alexdjm
    • Posts 19
    • Points 275
    Mi Marianna,
    Just to update. It starts up ok provided the sequence in use has no .mov /.mp4 ama'd clips showing in the monitor (it is mostly ama to RED files). As soon as you click over a .mov or .mp4 so it displays in the monitor,  2 red Quicktime_OPServer (not responding) errors pop up in the activity monitor and either it keeps running for a bit before crashing, or crashes straight away. If the curser is not already over a .mov / .mp4 then there is no error but if you try an output, the errors appear as before.
    Alex
