Latest post Fri, Mar 4 2016 3:31 PM by omsupport. 4 replies.
  • Tue, Mar 1 2016 1:41 PM
    • omsupport
    • Joined on Tue, Aug 20 2013
    • Posts 83
    • Points 900
    Search for checked-in assets only?
    It may just be me, but I'd find it useful to have a Search option that only returns checked-in assets. At the moment (unless I'm missing something) it always returns both checked-in assets and referenced-only assets and doesn't distinguish between them.
    That is, if I search for all assets inside a folder tree and there's a sequence using a load of clips, those clips are always returned even if they aren't actually checked into that tree anywhere. To tell if an asset is actually checked in I then have to use GetChildren on its parent folder to see if it gets returned.
    And I don't know if any enhancements are planned to the other Search parameters, but it would also be handy to define a User attribute as having a date value (at the moment date-based searches are restricted to System attributes).
    And to go the whole hog it would be nice to have STARTS_WITH and ENDS_WITH conditions for strings, or maybe even simple wildcard-matching.
  • Thu, Mar 3 2016 4:59 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
    • Avid Developer Moderator
      Avid Employee
    Re: Search for checked-in assets only?
    omsupport,
    Did you see the InUse flag in the Search() call?
    From the doc:
    The FileInUseConditionType XML type represents a condition based on whether or a not a file is currently labeled as in use (referenced by another asset). Not specifying a FileInUseConditionType will disregard the asset's state of usage.
    For example:
    <typ:FileInUseCondition InUse="true"/>
    Hope this helps.
    - Rob
  • Fri, Mar 4 2016 9:07 AM In reply to
    • omsupport
    • Posts 83
    • Points 900
    Hi Rob.
    I realise that I was mistaken - Search only returns checked-in assets, not references.
    However I'm still looking for an effective way to find all checked-in instances of an asset, as opposed to pure references (greyed out in Interplay Access). I'm using FindLinks (which returns all associations, both checked-in and otherwise) and then calling GetChildren on the parent folder of each returned link - this only returns checked-in assets so lets me tell the difference between a checked-in asset and a reference, albeit extremely inefficiently.
    As I understand it, the "in use" condition controls whether Search returns referenced assets, not assets which are themselves references.
    Geoff.
  • Fri, Mar 4 2016 2:26 PM In reply to
    • robg
    • Tewksbury, MA
    • Posts 494
    • Points 5,605
      Avid Employee
    OK, what you are looking for is an option in FindLinks to only return checked-in assets.
    Is this correct?
    - Rob
  • Fri, Mar 4 2016 3:31 PM In reply to
    • omsupport
    • Posts 83
    • Points 900
    Exactly. Though as I said I've got it working using a combination of FindLinks and GetChildren. It's just rather inefficient.
