Latest post Mon, Aug 28 2017 2:01 PM by pierreh. 116 replies.
Page 6 of 8 (117 items) « First ... < Previous 4 5 6 7 8 Next >
  • Sat, Feb 6 2016 12:16 AM In reply to
    • Fish
    • Joined on Sat, Oct 15 2005
    • Filet Post, Halifax NS
    • Posts 588
    • Points 7,320
    Re: Media Composer v8.5 | NOW AVAILABLE - w/El Capitan Support!
    On another note: I'm getting crash/exit error message when I select any test patters for output. None will display, all I get is an error and an insistence to exit to the Finder.
    More tests tomorrow.
    2012 Westmere MacPro 2 x 2.66 GHz 6-Core Intel Xeon) 6 GB 1333 MHz DDR3 ECC ATI Radeon HD 5870 1024 MB As of Jan 2015 - OS X 10.9.5 (13F34) [view my complete system specs]
    AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
  • Sat, Feb 6 2016 8:09 PM In reply to
    Still no Retina Display Support? I wonder if that is ever goihg to happen. I've been almost 5 year editing with a rMBP and the text in UI still looks blurry :/
    Mac Pro 2014 6 core 32gb RAM / AJA 4K IO / MC 8.5.1 / OSX 10.10.5 Retina Macbook Pro (Mid 2014) [view my complete system specs]
  • Mon, Feb 8 2016 7:52 PM In reply to
    I'm getting No LTC out from Nitris DX during audio punch-in with this version. Reverting to 8.4.1 restores this function. This, after deleting mcstate and site settings and new user settings failed to restore this function.
    4 Systems-> MacPro 5,1 OSX 10.11.6 32GB RAM Nitris DX MC2018.9 | 2 Systems-> MacPro 6,1 OSX 10.11.6 64GB RAM Artist DnxIO MC8.x Avid Nexis 2018.5 [view my complete system specs]
  • Wed, Feb 10 2016 3:40 PM In reply to
    • Jim Allan
    • Joined on Mon, Jun 7 2010
    • Oakville, Ontario, Canada
    • Posts 110
    • Points 1,240
    The Red Giant site now says "Magic Bullet Looks does not support Avid Media Composer 8.5 on Mac OS X 10.11".
    I went back to 10.10.5 because Looks is more important to me than Mac OS 10.11.
    MC v2021.9 with Phrase Find on a 15" MacBook Pro (2017). OS Big Sur v11.6, 3.1 GHz Intel Core i7. 16GB 2133 MHz LPDDR3. Radeon Pro 560 4096 MB. Intel... [view my complete system specs]
  • Wed, Feb 10 2016 10:51 PM In reply to
    I know it's not a fix but I'm finding it easy enough to round trip to Resolve to do any MB Looks work there.  The Looks license works in both host apps :)
    Hardware: 5K iMac (late 2015 17,1), 4 GHz i7, 32 GB, M395X w/ 4 GB, Promise Pegasus2 R4 in RAID 5 | Additional monitoring: 2.5K thunderbolt display, Dreamcolor... [view my complete system specs]
  • Wed, Feb 10 2016 10:57 PM In reply to
    • Andrew Rice
    • Joined on Wed, Aug 24 2011
    • Maui, Hawaii
    • Posts 155
    • Points 2,010
    MB LOoks is working for me on 8.5 in 10.11
    Media Composer 8.4 • Mac Pro • 2.8GHz Quad-Core Intel Xeon • 16GB RAM • ATI Radeon HD 5770 • Nvidia Quadra 4000 • Blackmagic Decklink Studio • BMD Desktop... [view my complete system specs]
    Glassy waves make me happy
  • Fri, Feb 12 2016 1:15 PM In reply to
    • cjdecko
    • Joined on Fri, Feb 12 2016
    • Posts 2
    • Points 10
    You'll need to remove AVX2 folder and then reinstall plugins again. It's possible that only  one of files is causing the problem, but you'll have to figure out which one is it. You can try removing one by one and see if it works.
  • Fri, Feb 12 2016 1:20 PM In reply to
    • cjdecko
    • Posts 2
    • Points 10
    http://community.avid.com/forums/t/137504.aspx?PageIndex=6
  • Sat, Feb 13 2016 10:23 AM In reply to
    • tonys
    • Joined on Thu, Jan 11 2007
    • Posts 102
    • Points 1,475
    Regarding compatibility with older versions, will I have any problems collaborating with other systems that run 8.3 in a shared storage environment ?
    Thank you
  • Sat, Feb 13 2016 9:36 PM In reply to
    v8.3.1 should be fine, as long as the project frame size and rate is compatible.
    v8.4 introduced custom frame sizes, so obviously using one would be an issue.
  • Tue, Feb 16 2016 6:00 PM In reply to
    • David Parke
    • Joined on Tue, Dec 6 2011
    • Los Angeles
    • Posts 30
    • Points 340
    I am having some timeline issues with it acting sluggish and unreliable while lassoing and dragging clips around. Running 10.9.5 on an early 2008 MacPro with 18GB RAM, NVIDIA GeForce GTX 870 3GB video card with a BlackMagic Intensity Pro 4k Card installed but not running an external monitor or anything. All drivers, software, etc. seem to be updated to their latest versions. Any thoughts? I suppose I'll try removing the internsity pro 4k card and see what that does but let me know if anyone has any other thoughts. I have attached a clip as a reference
    MC 2020.8.0 | macOS Catalina 10.15.7 (19H512) | 27" iMac 2020 3.8 GHz 8-core i7 | 40GB RAM | AMD Radeon Pro 5500 XT 8 GB | Archion shared storage [view my complete system specs]
  • Wed, Feb 17 2016 5:06 AM In reply to
    • Mike
    • Joined on Wed, Jun 29 2011
    • PA
    • Posts 124
    • Points 1,365
    Same issue here
    *0SX 10.14.3 *MC Ultimate 2018.12.3 *iMacPro (2017) 2.3 GHz Intel Xeon W-18cor*128 GB 2666 MHz DDR4*Radeon Pro Vega 64X 16 GB *AJA IO4KPlus *AVID ISIS... [view my complete system specs]
  • Wed, Feb 17 2016 2:58 PM In reply to
    I don't see anything like you are seeing Dave, but I am on El Capitan.
    You don't have to remove the card, but if you uninstall the BM Desktop software, do you see a difference?
  • Thu, Feb 18 2016 8:32 PM In reply to
    • David Parke
    • Los Angeles
    • Posts 30
    • Points 340
    So I went to uninstall the software and noticed it wasn't installed. Went to remove the card and I was mistaken -- no card installed at all! I am balancing 11 systems here so I must have mis-counted when I did the install. So this is happening on my system without the card or software installed. I changed out my mouse just in case but with the same results.
  • Fri, Feb 19 2016 10:37 PM In reply to
    • Jim Allan
    • Posts 110
    • Points 1,240
    Posted on the Red Giant site today:
    "Magic Bullet Looks (v. 3.1.4)
    • FIXED: Magic Bullet Looks is now compatible with Avid Media Composer 8.5 on OS X Yosemite"
