Latest post Tue, Dec 22 2015 1:06 AM by WAIF2318. 3 replies.
  • Sun, Dec 20 2015 7:06 AM
    • WAIF2318
    • Joined on Tue, Nov 15 2011
    • Posts 340
    • Points 4,205
    a problem for exporting~
    Color levels for exporting,what is the difference between"Keep as Legal Range"and "Scale from Legal to Full",which one should I select? any help is very thankful in advance.
  • Mon, Dec 21 2015 9:59 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 948
    • Points 12,125
    Re: a problem for exporting~
    With option "Keep as Legal Range" MC will export the current tineline/clip without making any modifications to the current color- and brightness values.
    When selecting option "Scale from Legal to Full" MC modifies/maps color- and brightness values from digital video levels with range 16 - 235 to full range levels 0 - 255.
    As MC is basically designed to stay within "legal" levels (16 - 235) according to ITU T Recommendations BT.601 and BT.709, it usually exports with no modification to the color- and brightness values. This is Standard Option.
    If you want to publish your final video on Internet, you may wish to have full color- and brightness range, as otherwise your colors look "washed out". In this case you should use the second option. This option is also needed for some DVD- and BD-authoring software to get full color range and not washed out colors.
    I hope this helps you for your decision.
    Joachimm
    Joachim Claus
  • Mon, Dec 21 2015 10:50 AM In reply to
    WAIF2318:
    Explanation in PDF here
  • Tue, Dec 22 2015 1:06 AM In reply to
    • WAIF2318
    • Posts 340
    • Points 4,205
    Thanks to above all reply.
