Latest post Mon, Mar 21 2016 8:05 PM by Isaac T.. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Dec 1 2015 3:57 PM
    • insch
    • Posts 337
    • Points 3,945
    Media Indexer issue
    I am now getting the following error messgae when launching MC - 'Could not connect to the Media Indexer. Verify the health of the Media Indexer service.' Then if I proceed it says 'You don't have access to MediaIndexer'.
    This never used to come up before and I'm not sure why it's come up now.
    Any advice?
    Mac Pro, 3.7 GHz Quad-core, 32GB RAM, G-Tech G-RAID Studio etc. [view my complete system specs]
  • Tue, Dec 1 2015 4:03 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Re: Media Indexer issue
    Are you working on an Interpay-connected Media Composer? If you don't have IP in your facility, someone made a change to your settings to point it to one.
  • Tue, Dec 1 2015 4:09 PM In reply to
    • insch
    • Posts 337
    • Points 3,945
    Thanks.
    I don't have InterPlay. How can I change my settings back again?
  • Tue, Dec 1 2015 4:24 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    So did you, by any chance, upgrade your software or install a patch recently? Most often when we see this it is because a customer ran an installer and chose to install the Media Composer Interplay version rather than the Stand alone MC software.
    Is that possible?
  • Tue, Dec 1 2015 4:39 PM In reply to
    • insch
    • Posts 337
    • Points 3,945
    I installed Glue Tools software to enable me to work with Phantom cine footage within MC. I wasn't aware of an InterPlay option though. I am not aware of any other bits of software that might be relevant. What should I do now?
  • Tue, Dec 1 2015 4:47 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    Can you give support a call? they can walk you through reseting your system to a stand alone state.
  • Tue, Dec 1 2015 5:07 PM In reply to
    • insch
    • Posts 337
    • Points 3,945
    Ok - so it's pretty complicated? Thanks for your help.
  • Tue, Dec 1 2015 5:18 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 17,731
    • Points 226,405
      Moderator: MCA Mac
    It's actually not that complicated but it's more than we want to do on the forums.
    I would start by unistalling the Glue Tools to see if that changes anything. If not, support can get you up and running again. Let me know if you run into any snags and I can advocate for you.
    Call 1-800-800-Avid and have your system ID ready to input into the phone tree.
  • Tue, Dec 1 2015 5:37 PM In reply to
    • insch
    • Posts 337
    • Points 3,945
    I've just uninstalled Glue Tools but that didn't fix it. Will call support.
  • Tue, Dec 8 2015 2:28 PM In reply to
    • Fish
    • Joined on Sat, Oct 15 2005
    • Filet Post, Halifax NS
    • Posts 588
    • Points 7,205
    Open the Console.
    Type "workgroupoverride ON"
    Restart.
    Poof!
    2012 Westmere MacPro 2 x 2.66 GHz 6-Core Intel Xeon) 6 GB 1333 MHz DDR3 ECC ATI Radeon HD 5870 1024 MB As of Jan 2015 - OS X 10.9.5 (13F34) [view my complete system specs]
    AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
  • Tue, Dec 8 2015 2:48 PM In reply to
    • insch
    • Posts 337
    • Points 3,945
    Fish:
    Open the Console.
    Restart.
    Poof!
    Yes, that's what support recommended. Thank you. It worked!
  • Mon, Mar 21 2016 8:05 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 759
    • Points 8,960
    +1
    Now if Avid could figure out why we're being given Interplay installs. I suspect it has something to do with their new(er) licensing model.
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
