Latest post Thu, Jun 24 2021 2:10 PM by chuckkahn. 14 replies.
Page 1 of 1 (15 items)
  • Mon, Nov 30 2015 12:14 PM
    • DJFio[DB]
    • Joined on Thu, Nov 3 2005
    • Moscow Russia
    • Posts 332
    • Points 4,505
    2019.6 MC Autosequence by AUX timecode
    Please add ability to select AUX timecode to build autosequence.
    I'm using audio timecode for syncing field cameras. (they have no TC in - only audio) I have 7 cams and they switch on/off randomly. I don't need a multicamera multigroup, because field cams have 1-10 frames random drift, so i can not then adjust my multigroup.
    So - i need a simpe timeline-camera-time-map  to edit.
    I extracted audio tc from my clips
    But now autosequence have only option to build a sequence using clip TC
    that's the problem.
    PLEASE add AUX timecode option to Autosequence.
    my zoo: NEXIS Pro 40 tb sw v19.12.0.5; MBPro_late_2013 15'' i7 16GBram OSX 10.15.7 MC 2020.12 BMD US monitor (or AJA io XT ), ATTO NT11;Baselight... [view my complete system specs]
    DJFio[DB]
  • Mon, Nov 30 2015 3:24 PM In reply to
    Re: Autosequence by AUX timecode
    Yes! +1
    This was feature-requested here in 2011.
    Squeeze v11 EOL-Pro Sony BM2100 Telecine with variable speed controller for silky smooth playback; Casio VL-Tone, CZ-101, LCD watch; AJA i/o Express with... [view my complete system specs]
    -Telegram!
  • Mon, May 9 2016 7:30 PM In reply to
    • Tilmann
    • Joined on Tue, Dec 3 2013
    • Sofia/Karlsruhe
    • Posts 13
    • Points 145
    +1
    or at least an option to batch update the Start TC with an AUX TC…
    Best, T
    2019 MBP, 2,4 GHz i9, 64GB DDR4, AMD Radeon Pro 5600M 8 GB, Blackmagic UltraStudio Express, MC 2022.04 on Monterey 2013 iMac14,2, 3,5 GHz Intel Core... [view my complete system specs]
  • Thu, Mar 2 2017 7:09 PM In reply to
    adding in my +1 in 2017!
    I'm on a project where they made extensive use of Tentacle sync.
    Being able to autosequence by Aux TC would make my life so much easier right now.
  • Sat, Aug 26 2017 5:42 AM In reply to
    • fsm
    • Joined on Tue, Nov 24 2009
    • Germany
    • Posts 181
    • Points 2,195
    ( :/ double post sorry )
    MC 2021.12 & SYM / BM Monitor4K / Windows 11 (i know ...) 64 bit / i7 12700k / RTX3070 [view my complete system specs]
    • fsm
    • Germany
    • Posts 181
    • Points 2,195
    need this to, would be a great timesaver +1
  • Thu, Sep 7 2017 9:12 AM In reply to
    • jrhagan33
    • Joined on Thu, Nov 29 2012
    • Posts 18
    • Points 260
    Yes please +1!
    This would save so much time syncing cams which don't jam TC so have been sent audio timecode instead.
  • Thu, Sep 7 2017 9:27 AM In reply to
    +1 - I use AUX TC all the time and this would be a huge help.
    I would hope this to be a part of a multicam improvement package allowing for multicam tracks to contain multiple non-continuous clips like FCP7 used to have and Premiere has had for years, but small steps..
    (SYSTEM 1) iMac Late 2012 27" (13,2), Mac OS X 10.15.6, Avid Media Composer 2020.12 w/Symphony, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX... [view my complete system specs]
  • Thu, Sep 21 2017 6:11 PM In reply to
    • DJFio[DB]
    • Moscow Russia
    • Posts 332
    • Points 4,505
    Please! Please! Please! Add tihs feature :).
    WE NEED THIS
    DJFio[DB]
  • Sun, Oct 21 2018 9:06 AM In reply to
    • Jack Woon
    • Joined on Thu, May 24 2012
    • New Zealand
    • Posts 17
    • Points 225
    I'd love for this feature to be added also - just an extra option that lets you choose which TC field to use when autosequencing. It's very rare these days to see timecode perfectly synced between cameras and sound recorders so we often create syncmaps to see problems and manually adjust sync before committing. Autosync has the option to use Aux TC but cannot be used to create sync maps. So the best solution is to add the option to autosequence.
    Hope to see this feature soon! It has been requested since 2011.
    Avid Media Composer 2020.4, Windows 10 2x Intel Xeon E5-2630 v4 @ 2.2GHz, 64GB RAM, Quadro M4000 [view my complete system specs]
  • Fri, May 31 2019 7:37 AM In reply to
    • Alexander P.
    • Joined on Tue, Aug 7 2018
    • Center of Europe
    • Posts 35
    • Points 405
    Still waiting for requested feature.... Maybe new method of syncmap creation by AUX TC is invented?
    12 PCs HP Z6, 3 laptops Dell, HP Zbook G6, AVID MC 2018.12.x licensed, MC 2020.x trial [view my complete system specs]
  • Fri, Jun 21 2019 1:19 AM In reply to
    I've had a similar request for a while:
    http://community.avid.com/forums/p/179829/837370.aspx#837370
    If not letting us use Aux TC column then that column should at the very least be able to be duplicated in the the Main TC column in much the same way as one would duplicate say, the clip name in to the Tape ID column through highlighting and using Ctrl+D
    Currently you hve to copy each one across one by one. Pointless waste of time.
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2021.12 MacbookPro 15 2019 6 core 2.6GHz i9 32GB... [view my complete system specs]
  • Fri, Jun 21 2019 4:12 PM In reply to
    +1 again
    -Telegram!
  • Mon, Feb 17 2020 1:21 PM In reply to
    • morsey
    • Joined on Thu, Dec 12 2019
    • Posts 49
    • Points 595
    +1
    I cut in hundreds of VFX shots per week and I have the timecode where they are to be cut in for each reel in the Aux TC1. I can't mess with the Start Timecode. This would be a huge time saver for VFX Editors/ Assistants on heavy VFX shows/ animations.
  • Thu, Jun 24 2021 2:10 PM In reply to
    • chuckkahn
    • Toronto
    • Posts 430
    • Points 4,800
    Re: 2019.6 MC Autosequence by AUX timecode
    Yes please!
    Avid Media Composer 2018.12.15 / MacOS Mojave 10.14.6 / iMac (Retina 5K, 27-inch, 2017) / 4.2 GHz Intel Core i7 / 64 GB 2400 MHz DDR4 [view my complete system specs]
