Latest post Tue, Dec 1 2015 8:11 PM by Concord. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Nov 5 2015 5:14 PM
    • Johnny Diesel
    • Joined on Mon, Oct 29 2007
    • Toronto, Ontario, Canada
    • Posts 61
    • Points 650
    New Quadro m4000. Anyone using it?
    Hi:
    Does anyone have experience with this? Should work as its replacing K series, but is not yet officially supported.
    New build and I would rather invest in M series rather than older K series, if it will work of course!
    How about driver version?
    PNY Quadro M4000 VCQM4000-PB 8GB 256-bit GDDR5 PCI Express 3.0 x16 Full Height Workstation Video Card , http://www.newegg.ca/Product/Product.aspx?Item=14-132-051
    thanks, John
    Homebuilt: Win 10 on Asus X99-E WS/USB 3.1, Xeon E5-1650 v3 at 3.5 GHZ 6-core, 32 GB DDR4 RAM, Nvidia Quadro M4000, Blackmagic Intensity Pro 4K. Canopus... [view my complete system specs]
  • Fri, Nov 6 2015 8:59 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 591
    • Points 6,995
    Re: New Quadro m4000. Anyone using it?
    should be fine.
    isnt a new card really, maxwell core from Q4 2014, same 28nm. expect 20% more than k4200
    big update will come with the next die-shrink in Q1 2016.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-7, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Sun, Nov 8 2015 12:55 AM In reply to
    • Johnny Diesel
    • Posts 61
    • Points 650
    Thanks Lukas. Not to quibble, but according to Anandtech, m4000 was released in August 2015. Perhaps we're thinking of different products?
    http://www.anandtech.com/show/9516/nvidia-announces-quadro-m5000-m4000-video-cards-designworks-software-suite
    So it's pretty new tech which SHOULD work, but I was wondering about a real-world experience opinion.
    John
  • Sun, Nov 8 2015 8:56 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 591
    • Points 6,995
    the card is newly released,
    the chip that's inside is a year old.
    the gpu market currently has a massive process node problem. we were supposed to be at 22nm a year ago, still stuck at 28nm. so we're seeing many souped up products.
    the chance that this card will work in avid is 95%, a risk i'd take
  • Thu, Nov 26 2015 12:11 AM In reply to
    • Concord
    • Joined on Mon, Jun 25 2012
    • Posts 8
    • Points 100
    If you are using the m4000, which Nvidia driver are you using?  I was told by Nvidia support that the340.84 driver is incompatible with the m4000 and to use the latest driver for the card which is 358.91 - which is not listed as supported on the Avid site.
    MC 19.12 on Custom PC. Dual 8 core Xeon processors at 3.2GHz, 64GB RAM, 1TB Samsung SSD for OS and programs, 4.5TB Samsung SSD for Avid Projects, NVIDIA... [view my complete system specs]
  • Thu, Nov 26 2015 7:57 PM In reply to
    • Johnny Diesel
    • Posts 61
    • Points 650
    Contact Marianna at marianna.montague@avid.com. She might be able to shed light on this
    John
  • Fri, Nov 27 2015 12:15 PM In reply to
    • Dan_B
    • Joined on Tue, Nov 26 2013
    • Posts 156
    • Points 1,695
    as the M6000 is on the supported list you'll be fine.
    For now at least i would use driver 347.52 as thats qualified up to the M6000 card
  • Mon, Nov 30 2015 5:32 AM In reply to
    • Concord
    • Posts 8
    • Points 100
    Thanks for the reply.  I tried to install 347.52 but get the message "This graphics driver could not find compatible graphics hardware." so this doesn't seem like an option for the m4000.
    • Concord
    • Posts 8
    • Points 100
    Thanks for the reply.  I will give her a shout an see what she says.
  • Tue, Dec 1 2015 9:04 AM In reply to
    • Lukas Boeck
    • Austria
    • Posts 591
    • Points 6,995
    MC 6.5 until compatible driver would also do the trick.
    more stable anyway.
  • Tue, Dec 1 2015 8:11 PM In reply to
    • Concord
    • Posts 8
    • Points 100
    Good news!
    I communicated with Marianna Montague and she told me support for the new Nvidia boards would be in MC release 8.4.3 and that it would require the 353.82 driver to work.
    Well, 8.4.3 came out today!  I installed it and also installed the correct 353.82 driver (my bad...) and lo and behold it all worked.  I verified that the M4000 was processing my MC renders using the Nvidia GPU resource meter.
