Latest post Sun, Jan 24 2016 6:22 PM by Tilmann. 7 replies.
  • Wed, May 6 2015 6:48 PM
    • gumbaedit
    • Richmond, VA
    • Posts 527
    • Points 7,000
    debugger when trying to import audio on mc8.3.1
    I'm getting the attached debugger message when trying to import audio into Avid.  It happens with both wave and aiff files.  48/24 in both cases.  I was using 8.3 but upgraded to 8.3.1 to see if it got fixed.  Running version 10.4 of BMD desktop.  not sure if it's related to that or not.
    ft abort called
    file:snapshots/relengmtnlion4_1425611347/coresw/core/utils/ECcore.c,
    Line:118
    Anone else having this issue?
    6 core Late 2013 MacPro 3.0 gHz, 16 gigs RAM, MC 8.8.5 on OSX 10.12.4, DNxIO, Flanders CM250, BMD Desktop Video version 10.9.1 [view my complete system specs]
  • Mon, May 11 2015 1:05 PM In reply to
    • gumbaedit
    • Richmond, VA
    • Posts 527
    • Points 7,000
    Re: debugger when trying to import audio on mc8.3.1
    Still an issue.  I ended up importing the audio in 7.0.4 and brought the bins into the 8.3.1 project.  synced some clips and then tried to slip perf and this is what I got:
    This makes 8.3 pretty much unusable for me.
  • Fri, Jun 26 2015 9:53 PM In reply to
    • gumbaedit
    • Richmond, VA
    • Posts 527
    • Points 7,000
    Ok.  Still busted in 8.4.  This means that MC is unuasable on my system, and when I say unusable, I mean that other than starting it up, I can't do anythng that resembles feature film or television workflow.
    Anyone else with this issue?
  • Sat, Jun 27 2015 9:01 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 607
    • Points 7,590
    No, not seen this. Can you post an example file for me to try?
    2021 MacBook Pro 16" (M1 Max 32GB), 2019 iMac 27" (8-core i9, 40GB) [view my complete system specs]
  • Sat, Jun 27 2015 8:36 PM In reply to
    • Steve Thomas
    • Joined on Thu, Jan 22 2015
    • Jacksonville, FL
    • Posts 7
    • Points 95
    I also ran into this problem over the last couple of days. It started when I upgraded my MBP Retina from 8.3.1 to 8.4. At first everything was fine, but after a few hours, I started getting the warning every time I tried to import or transcode a clip. Thinking that the issue might be with my MBP, I installed 8.4 onto my late 2013 Mac Pro only to find that I was getting the warning right away.
    I completely uninstalled MC off of both machines - first using the supplied uninstaller and then using the app Easyfind (free from app store) to search and delete all things Avid. I then reinstalled 8.3.1 to see if I would still get the same warning. 8.3.1 worked flawlessly for me. Feeling lucky, I then used the Avid Application Manager to upgrade everything to 8.4. It's been 24 hrs and 8.4 has worked perfectly. With that said, other than the complete uninstall/reinstall, I have no idea what fixed the issue. If Avid support can weigh in on the issue, that'd be great.
    FYI, I'm using a 2014 MBP Retina and 2013 MP both running latest versions of Yosemite 10.10.3. Clips that I was trying to import/link/transcode are Blackmagic 4K ProRes LT MOV files.
    Mac Pro 2019 3.3GHz 12-Core Intel Xeon W 96GB AMD Radeon Pro Vega II 32GB MacBook Pro 16 2019 2.3 GHz 8-Core Intel Core i9 32GB AMD Radeon Pro 5500M 8GB... [view my complete system specs]
  • Sun, Jun 28 2015 6:46 PM In reply to
    • Steve Thomas
    • Jacksonville, FL
    • Posts 7
    • Points 95
    With a little bit of effort, I was able to reproduce the problem. It seems (for me anyways) that when a new project is created at above HD resolutions (2K, 4K, UHD) at 23.976 checking the box Film 35mm, 4perf, the error message happens upon import, consolidating, or transcoding. I created several other projects with different combinations of formats, resolutions, frame rates, Film box checked/unchecked and all worked fine with no error messages. Interestingly enough, when I created a new project at 1080p 23.976 Film 35mm, 4 perf and then changed the resolution to 2K, 4K, UHD in the Format tab inside the project, again, everything worked fine with no error messages. Go figure...
    Again, this is only happening to me with 8.4 - did not have the problem with 8.3.1.
  • Mon, Jun 29 2015 2:27 PM In reply to
    • gumbaedit
    • Richmond, VA
    • Posts 527
    • Points 7,000
    Same results here, thanks for the testing.
    Seems like a pretty nasty bug for 24p workflows when you want the ability to slip perfs to tweak the audio.
  • Sun, Jan 24 2016 6:22 PM In reply to
    • Tilmann
    • Joined on Tue, Dec 3 2013
    • Sofia/Karlsruhe
    • Posts 11
    • Points 105
    exactly the same issue here. 8.4.xx, 2K, 24p, Film and no import possible. it happens also with ale-files.
    2013 iMac14,2, 3,5 GHz Intel Core i7, 32 GB 1600 MHz DDR3, NVIDIA GeForce GTX 780M 4096 MB, Matrox MXO2Mini, MC 8.4 w Symphony, OSX 10.10.2 2008 MacPro... [view my complete system specs]
    Filed under: , , , , , ,
