Hi there,
can anybody hlep me with export video from timeline to a dv file?
i found nothing like that in the corresponding menu.
is it just a rename-thing with a uncompressed different file format or is there no chance to put it out to a *.dv with liquid?
I need a dv-file for impoting in pro tools. with standard qiucktime it will show the video in a floating window instead of giving it out to another (third) device. So poeple in the pro tools forum told me to convert it to a *.dv and import to pro tools and it will work.
anybody else with experience wtih this kind of workaround ?
thnx for helping
Get yourself QuickTime Pro 7 and you'll be able to load your AVI files (fused from Liquid) into QuickTime and then export them out to DV. I suspect .DV is a repackaging of the AVI-DV from Liquid. I just tried this and the conversion was very fast.
Good luck
Steve
______________________
www.nelliedogstudios.com
hmmm,
ok thats a solution, but i spend 700 bucks and the ****software isnt able to give out the basic?!
Uncompressed *.dv.
Im speechless and on my way for qt 7 pro ;)
cheers
thanx barkinmadd
I have a feeling .DV is just DV-AVI with a different extension. It only seems to exist in the Apple world. I suspect if you just fuse your timeline with the Liquid DV-AVI codec, you will get the same result.
What application are you going to use these .DV files with??
LewS
Pro Tools 5.3.1 on MAC (God know that i hate them) with OS 9.i dont know.
and it drives me crazy, cause im biting teeth out past two weeks.
but im close to the solution i feel it ;)
ok converted files into *.dv
problem now is that i have to use the dv stream as it would be for internet and this includes i complession far as i can see. i got serious qualaity loss.
any idea ?
I created a .dif file (exported from AFter Effects), I then changed the file extension to .dv and the other system that I put it on saw it as an actual dv movie. I imagine if you fuse out of Liquid with the dif renderer and change the file extension it would do the same thing.
For test comparisons, we checked a .dv file from another source, but of the same footage. Both the .dif file and the .dv file weighed exactly the same, and looked identical in playback.
Mark
PS....buying QT pro was a good investment....you can use it to convert a lot more than just QT....
