Latest post Thu, Mar 19 2015 12:01 PM by JD Marlow. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Mar 10 2015 4:41 PM
    • JD Marlow
    • Joined on Tue, Jan 1 2013
    • NYC
    • Posts 75
    • Points 805
    Moire prone GFX look much worse in 1080i than 1080p
    Hey everybody,
    I'm running into something that I assume is common for some of you.  But I've not seen such a difference in quality with still photos between progressive and interlaced Avid projects.  Here are two screen grabs from a still photo I'm using in a project -- one imported into a 1080i 59.94 Avid Project at DNX220x, and one imported into a 1080p 23.98 project at DNX175x.  In motion, the interlaced version looks like a trippy vertigo experience.  We're trying to evaluate how much to blur this coming out of After Effects, but it's impossible to tell if this is just a product of being in an interlaced world or what.  Any thoughts would be really helpful!
    1080i INTERLACED
    1080p PROGRESSIVE
    Mac Pro 10.9.5 (Dual Quad-Core 2.26 Ghz), 16 GB RAM, Media Composer 7.0.4.3 [view my complete system specs]
  • Tue, Mar 10 2015 4:58 PM In reply to
    Re: Moire prone GFX look much worse in 1080i than 1080p
    Were these graphics scanned from halftone images (original coming from newspaper or magazine)?  My format is 1080i and run into moire issues with fine detail. I stopped scanning graphics and would instead put them on a copy stand and use a DSLR. Results are much better. A scanner emphasizes the half tone dots too much.
    I use After Effects for almost all photo moves. You can add a small amount of interlaced blur effect to lessen the moire as well.
    Lee
    Daytime Gig Gear Hardware: HP Z820 32gb ram • AJA Kona LHi • Xtore 5tb RAID • NVidia Quadro 5000 • JVC 24" HD-SDI monitor • Avid Artist Color &... [view my complete system specs]
  • Tue, Mar 10 2015 9:42 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 759
    • Points 8,960
    It's the interlacing.
    http://en.wikipedia.org/wiki/Interlaced_video#Interline_twitter
    Apply blur. Season to taste.
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
    isaact.co | Twitter | Instagram | Vimeo
    Writer: The Frame.io WORKFLOW Guide - http://workflow.frame.io/
    Post Workflow Consultant - https://isaact.co/
  • Thu, Mar 19 2015 4:03 AM In reply to
    • N Ryan
    • Joined on Thu, Jul 3 2014
    • Melbourne, Australia
    • Posts 93
    • Points 1,145
    Depends too on what you're doing with the image - are you enlarging it in MC?
    Best option is to add blur to the image BEFORE you import it. If it's 1920x1080, then a 0.3 Guassian blur might be enough, else try 0.4 or 0.5, but any more than 0.5 and you tend to actually see the image softening once imported. 0.3 tends to stop the flicker but not introduce any perceptible softening.
    Consider too, are you creating the image as 1920 x1080 outside MC, so that MC is NOT manipulating it on import?
    Neil.
    Media Composer 8.8.5.46340 with Symphony HP Z6 G4 Workstation 32.00 GB RAM Intel(R) Xeon(R) Silver 4116 CPU @ 2.10GHz BCC 12.0.4 Avid ISIS & Nexus [view my complete system specs]
    Neil.
  • Thu, Mar 19 2015 5:02 AM In reply to
    • dingo1
    • Grinnell
    • Posts 339
    • Points 4,045
    any different in pan and zoom?
    MC 2020.6 on 2019 MacBook pro 64 gigs ram Symphony v2018.12 on 2011 iMac i7 48gig ram tons of firewire single drives Symphony v 2020.4. on 2019 IMAC... [view my complete system specs]
  • Thu, Mar 19 2015 5:04 AM In reply to
    • dingo1
    • Grinnell
    • Posts 339
    • Points 4,045
    and yeah it is the interlace......P is your friend....
  • Thu, Mar 19 2015 12:01 PM In reply to
    • JD Marlow
    • NYC
    • Posts 75
    • Points 805
    We have had good luck fast blurring in After Effects prior to import.  Additionally, we have colored in stills like this so they are not black and white anymore.  That has helped a bit.  Some day maybe broadcast standards will move on from interlaced...
