Latest post Mon, Mar 2 2015 9:04 PM by mjolnarn. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Feb 27 2015 1:46 PM
    • dmfreeman
    • Michigan
    • Posts 1,862
    • Points 24,410
    Workflow for 4K media into 1920X1080 project
    Here is my issue.  I am shooting in 4K with a Sony FDR AX100.  My project is 1080i/59.94,  The Sony XAVC-S is 29.97 and is being converted using TMPGEnc Mastering Works 5 to 1080i.  Here is my workflow question,  I would like to import the 4K resolution into the 1080 project so that I can crop and use the higher resolution images.  Is this possible?  I realize that I would have to convert the native 4K files outside of Avid with TMPGEnc because there is no Codec for them, but can this be accomplished, or do I need to create a separate 4k project and bring my cropped files in from there?
    Any ideas?
    Denny
    Media Composer 2019.6, BCC Continuum 12.5, , Boris Red 5.6., Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows 10 Pro 1803... [view my complete system specs]
  • Fri, Feb 27 2015 7:45 PM In reply to
    Re: Workflow for 4K media into 1920X1080 project
    I just did a 1080i60 project with 4K ProRes as source footage.  AMA link is your friend. Keep the 4K ftg on a fast drive and AMA link to it. Frameflex will automatically be applied to the clips to squeeze them into a 1080 frame, but you can adjust Frameflex in the bin with source settings or using Effect editor once you get the clips in a timeline.  At some point you'll want to transcode your selects with your framings into DNxHD to smooth out playback.
    Lee
    Daytime Gig Gear Hardware: HP Z820 32gb ram • AJA Kona LHi • Xtore 5tb RAID • NVidia Quadro 5000 • JVC 24" HD-SDI monitor • Avid Artist Color &... [view my complete system specs]
  • Mon, Mar 2 2015 2:37 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,862
    • Points 24,410
    Thanks Lee,
    This does work, but the playback is very choppy which makes it difficult to apply filters to the timeline.  Still working on this, hopefully the experimentation will get me to a point where it is a bit more user friendly.
    Denny
  • Mon, Mar 2 2015 4:18 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,385
    Hi Denny, ama linked 4k might be choppy when playing out direct but you have lots of choices with 8.3 , using an offline workflow might be what you want to do , there are also both 1/4 and 1/16 workflows so lots of possiblities, should be a document about all this posted someplace.
    Tomas
  • Mon, Mar 2 2015 4:28 PM In reply to
    Tomas,
    mjolnarn:
    I only get those proxy options while working in 4K Format, not 1080. How do I go about working in 1/4 and 1/16 in a 1080 project?
    Lee
  • Mon, Mar 2 2015 4:33 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,385
    Hi Lee , maybe start in 4k and 1/16 when doing the rough cuts but there are lots of possibilities so it´s a users choice I believe, also depending on system power, disc speed , what 4K codec that is linked to etc etc so the list can be pretty long.
    Tomas
  • Mon, Mar 2 2015 8:25 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,385
    SamDogDigital:
    Also noticed this and it will not give you the best quality imho as a transcode not renders.
    Look at it as a motion adapter , you don´t want to import or transcode media with different framerates, you apply the motion adapter, do your adjustments and render settings and render the applied effect.
    Same goes with Frameflex, it needs to be rendered to give you the best quality.
    Tomas
  • Mon, Mar 2 2015 8:34 PM In reply to
    mjolnarn:
    Tomas,
    Is that still true with v8.3?  I had to render AMA Frameflex clips with v8.2 to get ultimate quality.
    With v8.3 there is the option in the Consolidate/Transcode utility to "Apply source transformations" to Frameflex. I thought that was the Avid solution for making sure the AMA Frameflex clips were at their best quality after transcode.
    Lee
  • Mon, Mar 2 2015 9:04 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,385
    I would never trust a transcode to do a good render job myself no matter what is written in the books, maybe I have missed something but this is my take on it.
    Usually I´m not very fond of Video Mixdowns but this might be the place to do it , when you are downscaling 4K to HD , no unnecessary file creations, just relink to the origin 4K and do a VM , then export QT ref or SAS .
    Tomas
